Marko_JJ Posted August 3, 2006 Share Posted August 3, 2006 Recently I was asked to do a site plan overview for a housing developement in the mountains. I told them I specialized in 3D so they told me to do it up in 3D but my results turned out too realistic they said. They wanted a more dreamy feel with watercolors and such. I tried alot of filters and different modifications in photoshop but I couldnt achieve the look they were going for. I had to tell them to use an artist because their timeline was tight and I didnt want to waste their time. I cooked up some extra balcony view renders so I didnt leave them empty handed. I was just wondering if any of you know how to achieve a watercolor painting dreamy look but with using 3D. Any suggestions? Mark J Link to comment Share on other sites More sharing options...
AJLynn Posted August 3, 2006 Share Posted August 3, 2006 What software do you use? Link to comment Share on other sites More sharing options...
Marko_JJ Posted August 3, 2006 Author Share Posted August 3, 2006 softimage xsi and photoshop Link to comment Share on other sites More sharing options...
mskin Posted August 4, 2006 Share Posted August 4, 2006 can i see the images? Link to comment Share on other sites More sharing options...
AJLynn Posted August 4, 2006 Share Posted August 4, 2006 Have you tried rendering in passes? mental ray should give you a lot of flexibility to do this kind of thing - get a shadow pass, a contour pass (does XSI give you a decent set of tooning tools?), GI and/or AO + shadow, more if you think it's necessary, then comp them in Photoshop - this gives you the most control. You can run filters on particular layers, or use layers and brushes to get a watercolor effect. For example, using hatch on your AO and shadow layers (keep the shadow layer at a low opacity), keeping your contour/toon layer normal and using a layer comp to "paint" your color layer onto a blank layer can give you the look of a perspective drawing that's been hatched in then watercolored. There are a lot of possibilities so mess around a bit and figure out what works best for your project. Link to comment Share on other sites More sharing options...
Arnold Grove Posted August 4, 2006 Share Posted August 4, 2006 Hey Marko, check out Fractal painter. Its amazing really. It lets you choose any paint medium. Water color, gwash, oil, pen, ink, pencil, crayon, you name it. And also lets you paint on any texture, paper, canvas, etc. You can also take photos and turn them into water colors. It uses layers, and if you have a stylus, you can really do just about anyhting. With your skill level you should pick in up inside of a few hours. Good luck, Cheers, Arnold Link to comment Share on other sites More sharing options...
Justin Hunt Posted August 4, 2006 Share Posted August 4, 2006 I second that one, although it is Corel Painter;) JHV Link to comment Share on other sites More sharing options...
AJLynn Posted August 4, 2006 Share Posted August 4, 2006 I remember it as Fractal Design Painter. I still have one of the paint cans that it came in. Link to comment Share on other sites More sharing options...
Justin Hunt Posted August 4, 2006 Share Posted August 4, 2006 It used to be Fractal, then Corel bought it a couple of years ago now its Corel Painter9.5 http://apps.corel.com/painterix/home/index.html JHV Link to comment Share on other sites More sharing options...
Arnold Grove Posted August 4, 2006 Share Posted August 4, 2006 Jeeze I knew that,,,, I cant rememebr who the maker was. I bought it in 97' or 98' and it's the only version Ive ever used. Few and far between because Photoshop has been my weapon for tv graphics. Unfortunatly not much artistic need for news graphics! I dont about the Corel version but Im sure its even better. Link to comment Share on other sites More sharing options...
Arnold Grove Posted August 4, 2006 Share Posted August 4, 2006 Yeah, LOVE the can too! Link to comment Share on other sites More sharing options...
i_petar Posted August 4, 2006 Share Posted August 4, 2006 Hi, Mark! Why don't you try Gertrudis. It works very easy, and the results are terrific. http://www.gertrudisgraphics.com/ Link to comment Share on other sites More sharing options...
Marko_JJ Posted August 15, 2006 Author Share Posted August 15, 2006 Thanks alot guys, Im checking most of those things out right now. I actually found some other ways to give it a slight watercolour look using photoshop. Once i am finished i will show u the outcome. Im going to try some of those other programs though. Thanks again! Link to comment Share on other sites More sharing options...
