nzjimmy2001 Posted August 9, 2006 Share Posted August 9, 2006 hi guys my scene has alot of windows. i'm using AGS glass, but whenever i press render max has an error and crashes. what can i do to prevent this? i have 2GB ram... would i possibly need a computer upgrade?... or is there some other way to get around this problem? thanks for your help in advance. Link to comment Share on other sites More sharing options...
nzjimmy2001 Posted August 9, 2006 Author Share Posted August 9, 2006 attached is my error message. Link to comment Share on other sites More sharing options...
Devin Johnston Posted August 9, 2006 Share Posted August 9, 2006 This could be caused by a material that has become corrupted. Try this: -Open your scene -switch you default render engine from Maxwell to Scan Line -Open the material editor, and then close it -Switch back to Maxwell -Save the scene without doing anything else -Close Max _Open Max and your Maxwell scene This will clear out all the Maxwell materials, you will have to put them back in the material editor but hopefully you will have fixed the crashing problem. Link to comment Share on other sites More sharing options...
nzjimmy2001 Posted August 9, 2006 Author Share Posted August 9, 2006 thanks for the suggestion devin. i'll try it out tonight. i'll let you know how i get on. :] Link to comment Share on other sites More sharing options...
nzjimmy2001 Posted August 10, 2006 Author Share Posted August 10, 2006 thanks anyway but it didn't work. it didn't clear out my materials either. i thought i'd start from scratch with new materials but the error still happens. any other suggestions? Link to comment Share on other sites More sharing options...
Koper Posted August 10, 2006 Share Posted August 10, 2006 looks like a memory failure. Try rendering without the actual rendering window, you can choose this in the rendering menu. I think its a check box called 'display render' or something good luck Link to comment Share on other sites More sharing options...
Devin Johnston Posted August 10, 2006 Share Posted August 10, 2006 That should have cleared out all your Maxwell materials and replaced them with default scanline materials. What version of Maxwell are you using? Link to comment Share on other sites More sharing options...
nzjimmy2001 Posted August 10, 2006 Author Share Posted August 10, 2006 cheers guys... i'll try the rendering without a render window... see if that helps. i may have to take the plunge and buy a new computer.... but then my worry is that i spend alot of cash only to find the error still occurs. :\ i'm using maxwell version 1.1. i reset all the materials to the default with the reset command then re-entered new ones but error still happens. Link to comment Share on other sites More sharing options...
Koper Posted August 11, 2006 Share Posted August 11, 2006 if you can, try rendering on another machine which is similar to yours, if it still doesn't work, then its the scene, maybe somebody here can help you on this Link to comment Share on other sites More sharing options...
