medopal Posted August 9, 2006 Share Posted August 9, 2006 hi guyz, here is a building made with 3ds max 8 with vray 1.47 i feel there is something missing in this image, can u help me plz, i want to make it perfect plz i want ur C 'n C Link to comment Share on other sites More sharing options...
Koper Posted August 10, 2006 Share Posted August 10, 2006 your link is broken, i can't access it. maybee post it here inside the thread Link to comment Share on other sites More sharing options...
Thiago de Andrade Posted August 10, 2006 Share Posted August 10, 2006 The main problem is the lightning, use a sun light and a skylight. Materials and modeling need improvement as well. Keep posting so we can help you. Link to comment Share on other sites More sharing options...
Buffalo Bills Posted August 11, 2006 Share Posted August 11, 2006 Here are the things I see. 1. You need to figure out a sun direction. Right now it doesn't even look sunny,especially with the background you have. 2. Materials need to be worked on. The block is too big and too sharp looking. The road material is big, and the paint lines need to be smaller. 3. I would replace the cars with better ones. The Palm trees could be better as well, too repetitive. 4. Composition can also use a little tweaking. You have too much ground and not enough sky. Crop it in. Hope this helps, keep us posted! Link to comment Share on other sites More sharing options...
