FlytE Posted August 10, 2006 Share Posted August 10, 2006 Ive encountered a nuisance problem recently. I use isolate selection all the time but for some reason now the "exit isolation" window has disappeared making it difficult to get back to the full model. Anyone know why this is or how i get it back? Link to comment Share on other sites More sharing options...
notamondayfan Posted August 10, 2006 Share Posted August 10, 2006 it happened to me a while back. think i just restarted vis and maybe my PC and it appeared again. Link to comment Share on other sites More sharing options...
FlytE Posted August 10, 2006 Author Share Posted August 10, 2006 Yeah, I tried both and it has made no difference. In the last day or so I have switched to a temp monitor while my old one is in for repair. The old one was a 20" 1600x1280 dpi , whereas this 'new' one is 1280x1024. Im wondering if viz is somehow still working to the older bigger resolution and displaying the floating window outside the 'grabable' user interface of the current resolution.... either way the problem still exists. Link to comment Share on other sites More sharing options...
notamondayfan Posted August 10, 2006 Share Posted August 10, 2006 try messing around with your screen resolution. try running vis in safe mode, and see if its there. i also looked, but couldnt find, a short cut key in the UI settings. Link to comment Share on other sites More sharing options...
Tim Saunders Posted August 11, 2006 Share Posted August 11, 2006 Even exiting your scene keeps it in isolation. However, selecting a new object, then isolating it and exiting isolation mode will go all the way back to totally un-isolated. Hope that helps. Link to comment Share on other sites More sharing options...
