VRAY only uses one process module on some geometry
Jefferson Grigsby
Working on a file with a 64 bit dual dualcore machine. It breaks the irradience map renders down to 8 buckets, each using 12.5% of the total process modules. The problem is that some files will show all 8 buckets on the screen, but when looking at the CPU in the task manager under respurces, it says it is only using 12-13% of the CPU while rendering the scene. Ideally this would be pegged at 100% This only occurs on some files. Has anyone else been able to pin down why this happens, it really seems to slow down my renders.
Thanks
Jeff
