Anyone ever made a 'hand sketched' animation?
Brian Smith
Another option is to render the animation as a typical "photo-real", then take a frame into Photoshop, start recording your actions - and play around with the various filters until you get the look you want. Then all you have to do is Automate/batch the rest of the frames out. It takes a while if you have a lot of frames, but the results can turn out looking pretty cool.
(see the demo image at turbosquid - http://www.turbosquid.com/FullPreview/Index.cfm/ID/309221 )
That's pretty impressive to me- have you seen any examples of architectural renderings done with that app in this style?
Calvino56- Can you point me towards a resource that explains how this is done in more detail? I've always wondered about doing that, but haven't had any idea of how to run an animation clip through Photoshop (or how to reassemble the clip afterwards). Yeah, I'm a newb to animation.
Some of the shots remind me of the sketch module of Poser. It's actually pretty good.
That's my usual workflow.
As described in a post above, you take a representative frame (save to a new name first) and click the start of a new action. Do your adjecting, filtering, whatever and when you are done click to stop recording.
With no file open, go to file>automate>batch and select your recorded action, point to the folder with your frames (A COPY OF ALL YOUR FRAMES!) tell it to over-ride profile warnings and save-and-exit, let it rip.
That's all there is to it. Actions can't do certain functions, but most things it can. Try to use general color or contrast corrections as the same settings will be used for all frames. Do not select colors or parts of the image since each frame after will be different. You cn set a new foreground color and then select a color range for example, but always establish a 'base' of a color or go back and set the background layer active before doing a new set of things, that sort of thing.
Certain layering effects that involve loading other renders are too hard to program in Photoshop. It can be done, but not my mere mortals. For that you will need After Effects or similar.
ernest, ive tried doing this using PS, but i cant for the life of me get it to work fully automated.
either i can do your work flow, but doing this way always asks me for my jpeg options, and so i have to manually click ok, which isnt very automated :)
the other way was to use the destination options, and give it a different file extention, but it still comes up asking for the options.
any ideas? (btw the PS help files are about as much use as a chocolate fire guard!!)
...about as much use as a chocolate fire guard!!
Please do not explain what that means. I don't want to know.
Save to TIFF.
Never render animation frames to, or save them out of PS in JPEG. It adds multiple layers of compression that way. Only compress upon output of your video editing software. Hard-drives are cheap.
