Long saving time
Msamir
... turn off auto save.
... you're living dangerously mate!
from a hardware standpoint ~ save time primarily comes down to hd speed and cache. If your system is a few years old or is a laptop, chances are it's only a 4200 or 5200 rpm hd with not a lot of cache... slow saves (with files that big anyway) are normal:p
na not if you get use to hitting ctrl+s every 2 seconds :)
that itself can be counter-productive when you're saving 53mb files on a slow HD.
ive relied on auto save too many times before, only to find the only autobak file was about 3 hours out of date!
... have you set the autosave? I guess I've been lucky and not had problems.
I'm sure there can be some scene optimization for that file... unless the 53mb is a single object:D If the saving is that slow, break the file up into parts, work on each of them as needed and then recombine for rendering.
  • 11 months later...
having the same problem
35 meg file, no x-refs, no ACAD data, everything collapesed
theres a quite a few groups though....seem to remember somewhere that slows things down
soooooper annoying !
that's not big enough to be anything other than a few second save. I've got a 39mb file open without any groups or the other stuff you mentioned above and with my 10k raptor sata hd, my saves are taking about 15 seconds. A 7200k disk should be right around there too.
[rant begin]with regards to your workflow and everything migrating to 64bit and therefore, much larger data sets, storage speed is becoming (or should be) an increasing concern for us all. Processors are getting faster by the day while storage is not... at least the parts that are available to us as lowly consumers. [rant over]:p
How much 3d space do you use, I have found that if you are working a far way from the center (x0,y0,z0) then it takes a bit longer to save. Half the time when I import cad drawings they are waaaay off center, then I just group everything and right-click the xyz input boxes at the bottom.
Have anyone used the 'compress on save' function? (see the image tecton3d posted) its gr8, from a 200mb file it save it into a 9mb file (don't think saving times are reduced though).
i leave it on all the time, and love it. i have always wondered if the compression slowed things down due to the time it would take to compress and decompress.
I have a file that is 53 MBs and everytime I save it takes too long, is there a way to lower the savings time ?
back to the large file size, have you run garbage collector on it? in the max script dialog box, lower left corber, type... gc()
hmmm. i hadn't heard that. i tried it in 9, and it didn't reject the command. ...but it didn't reduce my file size any either.
Yes I also tried it and didn't reduce anything apparently it was a problem and was solved in the max 8 Link
