New interior and problems
ebad
Hi all!
This is my new interior and is in progress...
I made the curtain but i dont like that! I think the material has some problems.
I used a standard with opacity of ~ 80.
May you help me to find a good solution?
Thank your dear Sir!
But my curtain has folds just like yours..Sorry i didnt understand "Up the 'irredesance'."!! Can you help about the material please?
Sorry man,
I am a Maya user dont know what you use? Specular, irredesance, incancesance?
Let me know i will try to help out,
been a while on max but will try to help.
Go with the first. Some modeling improvements on the curtains would help, but I believe this may be a perfect opportunity to play with the new Vray 2-sided material. You can give it your desired opacity in the refraction while giving it a slight translucent effect. Give it a shot an let us know.
Ya, with vray materials you adjust the transparency amount by changing the refraction amount by adjusting how white or black the colored box is. Totally black is fully opaque, pure white is fully transparent. I just figured sinse you are using the new v-ray, you should take advantage of it. The new spot3d help files outline how to use the new materials, but that 2-sidded material would be perfect for those curtains if you decide you want them back in your scene.
By the way...
Can any one help me to understand these new color mapping types:
Intensity exponential
HSV Exponential
And
Exponential
I used Exponential in all off these works.
May some body help about usages please?
Ya, with vray materials you adjust the transparency amount by changing the refraction amount by adjusting how white or black the colored box is. Totally black is fully opaque, pure white is fully transparent.QUOTE]
Funny, I had a long discussion in the office about the fact that Vray discribes opacity as refraction. Why? opacity isnt refraction, refraction is the distortion of light ie IOR. Had me confused for a long time
JHV
Funny, I had a long discussion in the office about the fact that Vray describes opacity as refraction. Why? opacity isn't refraction, refraction is the distortion of light ie IOR. Had me confused for a long time
JHV
It's an easy misunderstanding, but my last comments on the subject are that refraction is more about how light passes through surfaces than the distortion of light. The amount of "distortion of light" has to do with the IOR. Two separate values there (even though the IOR adjustment is controlled within the refraction parameters). So it actually makes sense that a material that is more transparent would have more light pass through it, thus adjusting your refraction amount. Sorry ebad for the slight diversion.
Here i tested a new scene...
I put a curtain here with this material but there was problems in curtain and all scene was noisy.. I didnt save any one :( :(.
Standard material:
opacity: ~ 50
Reflection : Vray map (Reflect -Reflect on back side checked) = 30
and one time with Vray material:
Refraction value : 50
Index of Refraction : 1.0
But i faced with the same result.
Lets see.. My light sources are behind of the curtain.Is there any problem with lights.Do you like i make a render with this tragedy?
What do you see about these pictures with no curtain?
THX.
I dont know what was the problem i just deleted the windows glass.
My window's glass was some things like the Vray curtain material i described below.
One question remains to be answered:
What could be the glass material? I like have some reflection of room on the window's glass.
Thanks a lot for your attention.
The Standard material for curtain in the left side:
Diffuse color : full white.
Spec level : 30
Glossiness : 10
soften : 0.5
Opacity : 60
Vray map with no 'reflect on back side' checked, assigned to the reflection slut arround 25.
The VRay material for the curtain in right side:
Diffuse color : Full white.
Reflection color value:15
Refl.glossiness : 0.6
subdives : 3
Refract color value:171
Index of refract : 1.0
No Translucent checked.
Ward Shader.
Coming along ebad. Strange stuff about your glass. Can't you just make it not cast shadows and still get reflections? I've got to jump bak on the curtains though. Doesn't your version of vray feature a vray 2 sided material? If so, try it out. It's not just a vray material, it's specific for stuff like this.
Yea..I've it,but what should i use as front and back stuff? Are'nt they some thing like mine?
About the glass;
You mean,turn off cast shadowing in glass properties (Rendering Control part)?
I'm testing...
THX.
I'm Heared your advises;
Used the VRay2Sided material for the curtains in the first picture.
No back material.
One vray mtl for front material with default settings and double sided turned off.
The translucency remains 0.5
The render time increased (About double).
By the way,About the window's glass I used a standard material with low opacity and vray map for reflection slut and cast shadowing turned off for glass object.
The result looks better but i'm not sure.
May you keep on your helps please?
Thx
Yeah, I think your getting it. I like the second one better. That very subtle reflectin helps. There may be just a little bit too much translucency going on with the curtain, but that looks much better than before. I'm not sure how walls are made in Iran, but I have never seen walls that bumpy. Also the camera angle is really high. It's probably best if you place the camera about eye level, not level with the fan. Good work.
Thanks dear Tim.
Be sure about walls they are not nowhere and i've edited it. ;)
But just one important point:
I feel this kind of material has no good relation with light cache..
The progress time for it increased about 55 min with the same settings when the last one with out curtain was arround 10 - 15 min.
Also the IRR progress increased arround 2 times.
Totally ~3 hours for progress before rendering (1400 * 1050) :(
I'l attach the new render once it finished.
Thx.
