drvox Posted August 14, 2006 Share Posted August 14, 2006 Hi gurus Here is attached a sample of what I get when I set a background image in render/environment/background map... I only have this problem when using vray... Any help is usefull... Thanks a lot Link to comment Share on other sites More sharing options...
JamesTaylor Posted August 14, 2006 Share Posted August 14, 2006 this has been discussed / solved before... try doing a search, i'm pretty sure i've even posted a solution somewhere, unfortunately i can't remember what it was!! Link to comment Share on other sites More sharing options...
JamesTaylor Posted August 14, 2006 Share Posted August 14, 2006 i've just done a search myself, but i can't find anything.... i'm sure this has come up before, and i seem to remeber it being an easy one to correct Link to comment Share on other sites More sharing options...
jow Posted August 14, 2006 Share Posted August 14, 2006 Its cos you are using "screen" mapping for the bitmap, change it to spherical or even better add it in post. Link to comment Share on other sites More sharing options...
LordRaven Posted August 14, 2006 Share Posted August 14, 2006 make sure you have the bitmap in the max's environment slot and NOT in vray's environment rollout under reflection/refraction. Link to comment Share on other sites More sharing options...
drvox Posted August 16, 2006 Author Share Posted August 16, 2006 Actually I've set the background in 3dsmax, not in the environment of vray settings.. Jow how can I change the mapping like you said? Jet10005, but I couldn't also find the post but thanks anyway for thehelp:) Thanks all Link to comment Share on other sites More sharing options...
drvox Posted August 16, 2006 Author Share Posted August 16, 2006 I've done a few tests and I realised that the background only crosses with objects when I turn on GI. Here is also something strage to me..I tried to render the same scene but: -turned off the background image -got two Free Area lights outside near the windows -one target point getting the sun effect -the windows are pure vray glass That's what I got...It just seems a night scene and windows seem to have black glass.. I'm having some trouble to render a daylight interior scene... any help? By the way, where do I get high qualiti image to get a nice print? This was a test and has low subs but even if I increase subs the image quality increases but not pixels for a good print... thanks a lot! Link to comment Share on other sites More sharing options...
jow Posted August 16, 2006 Share Posted August 16, 2006 Drag the enviro bitmap to your material editor then change the mapping there. The scene is dark cos ethier a, your glass mat doesn't have "affect shadows" ticked or your vray lights are the wrong way round and not invisable... Link to comment Share on other sites More sharing options...
