t0ffer Posted August 16, 2006 Share Posted August 16, 2006 hi there, this is my first post here.it´s a test of cinema 4d´s material and light system,aswell as the GI settings.i have read about how max and vray are the combination of choice for visualisation in this forum alot.since i am using c4d for sometime now and got used to it´s tools and workflow i would like some c&c on this image.this is what came out of the AR in cinema without any photoshop retouch.original render time was about 4.5hrs. thanks alot [ATTACH]15897[/ATTACH] Link to comment Share on other sites More sharing options...
STRAT Posted August 16, 2006 Share Posted August 16, 2006 not perfect by any means, but a good example of the great quality the AR can produce. nice render. although the 4.5 hour render time is pretty horendous with some optomisation of your settings this scene could be rendered in minutes instead of hours. Link to comment Share on other sites More sharing options...
Sindala Posted August 16, 2006 Share Posted August 16, 2006 very nice image! i like it alot. especially the green glow and the spots in the ceiling, but shouldn't the spots be reflected in the floor? also the light at the back is a bit overbright, but it does give some needed depth to the image! what was your original output size? Strat, i'm curious what you mean about the settings. 4,5 hours seems ok to me for this type of lighting Link to comment Share on other sites More sharing options...
STRAT Posted August 16, 2006 Share Posted August 16, 2006 what was your original output size? Strat, i'm curious what you mean about the settings. 4,5 hours seems ok to me for this type of lighting i mean i was curious about his gi settings. a few essential tweeks here and there could literally half the render times. Also, which i'd personally do, is turn the diff depth to 1 (which would save 99% of the render time) and compensate with localised infil omnis. with a bit of fiddling and experience you'd get the same results. area shadows slow things down to a crawl too. if this picture is the original output size then 4.5 hours is way over the top imo. also, i'm comming from a dual processor point of view Link to comment Share on other sites More sharing options...
t0ffer Posted August 16, 2006 Author Share Posted August 16, 2006 thanks for ur comments, original output size was 2551*1999,each visible light in the scene is a spotlight source.i used seperate passes for each light to tweak them later in PS.all lights use area shadows(i guess that´s what "flächenschatten" is in english). it was renderd on a dual opteron 2.4 with 2 gig´s of ram i am not at my workstatoin at the moment to give u the precise settings,but it´s best AA probaly 400 stochastic ray´s,min 100,max 120 (samples).ray depth 3.will post all settings once i am back thx Link to comment Share on other sites More sharing options...
NOOXY Posted August 16, 2006 Share Posted August 16, 2006 first off welcome...hope you learn lots of stuff in here..cause i sure did.. your image isn't too bad..you can feel the overall depth of the space..seeing you don't get many post in here from cinema4d i think you did a good job on this one...i agree with strat though with a scene like this and a few tweaks here and there your render time should be cut down in half the time..maybe you can post a scene file so we can work with..just a thought;) Link to comment Share on other sites More sharing options...
t0ffer Posted August 16, 2006 Author Share Posted August 16, 2006 thanks, i am sure i will learn a lot around here,once i am back in the office i will see wether i can post the scene file.not sure because of quite large texture sizes for the floor.thx again Link to comment Share on other sites More sharing options...
Sindala Posted August 16, 2006 Share Posted August 16, 2006 the problem i always have with infill omni's is that there are always white area's visible on the ceiling, how do you avoid this? i just upp the depth to 3 or 4 if needed, and that does give huge rendertimes. Link to comment Share on other sites More sharing options...
t0ffer Posted August 16, 2006 Author Share Posted August 16, 2006 i try to avoid omnis for the same reason.in this scene i used spotlights,wich are more precise in control.(inner and outer angle) Link to comment Share on other sites More sharing options...
STRAT Posted August 16, 2006 Share Posted August 16, 2006 the problem i always have with infill omni's is that there are always white area's visible on the ceiling, how do you avoid this? make sure they have specular turned off, and use far clipping instead of falloff. also, use them as ambients instead of diffuses. and if you do get specular blooms on things, use more omnis with less intensity. infact, the more the better really. Link to comment Share on other sites More sharing options...
Sindala Posted August 16, 2006 Share Posted August 16, 2006 oooo, i never that specular thickbox before, that's really a good tip! I owe you a beer!! Link to comment Share on other sites More sharing options...
edub Posted August 17, 2006 Share Posted August 17, 2006 hi there, this is my first post here.it´s a test of cinema 4d´s material and light system,aswell as the GI settings.i have read about how max and vray are the combination of choice for visualisation in this forum alot.since i am using c4d for sometime now and got used to it´s tools and workflow i would like some c&c on this image.this is what came out of the AR in cinema without any photoshop retouch.original render time was about 4.5hrs. thanks alot [ATTACH]15897[/ATTACH] I'm really intrigues by the green light glow, especially where it shows in the conveyor belt. Would you mind sharing your settings for the glowing green glass? Is it just the luminance channel? I've been trying to achieve something like that myself, but end up with too much saturation in the surrounding space. Good job. Link to comment Share on other sites More sharing options...
GeraldH Posted August 17, 2006 Share Posted August 17, 2006 >...I owe you a beer!! Don't beer the animals... Link to comment Share on other sites More sharing options...
t0ffer Posted August 23, 2006 Author Share Posted August 23, 2006 here are the settings for the green glass.... took a while first day back to work... grtx [ATTACH]16016[/ATTACH][ATTACH]16017[/ATTACH][ATTACH]16018[/ATTACH] [ATTACH]16019[/ATTACH][ATTACH]16020[/ATTACH] Link to comment Share on other sites More sharing options...
