hurairah Posted August 16, 2006 Share Posted August 16, 2006 hye guys, how to make 3d carving from an image?thanks for a little help[or more..]heh.... Link to comment Share on other sites More sharing options...
IC Posted August 16, 2006 Share Posted August 16, 2006 If I understand what you mean, you have a few options. You could model it using the image as a background template. Just boolean or drill the holes or painstakingly model it piece by piece. There's no quick explanation for modelling something like that I'm afraid. The easiest way would be to make a bump and transparency map from the image. Then apply those to a box depending on the effect you need. Link to comment Share on other sites More sharing options...
Sawyer Posted August 16, 2006 Share Posted August 16, 2006 There is also a way to import an illustrator path and extrude it. I imagine you would be most satisfied with box modeling however. Link to comment Share on other sites More sharing options...
BrianKitts Posted August 16, 2006 Share Posted August 16, 2006 my vote would go to just making it a box with an opacity and displacement map. Link to comment Share on other sites More sharing options...
hurairah Posted August 17, 2006 Author Share Posted August 17, 2006 ok..i'll try.anyway...thanks alot:cool: Link to comment Share on other sites More sharing options...
