maxkid Posted August 17, 2006 Share Posted August 17, 2006 Hi guys, I am working on max7 ,trying to render a hi -res aerial photo ,it is 40 mb file ,i also croped it and got it to 10 mb size still it gives memory error in 3dmax7 ----any idea how do i deal wit this aerial map 1) it is aerial jpg image with 12,947 by 23,729 pixels i got this down to 7,540 by 15,000 pixels ,still it does not render......it give error satinbg not enough memory ,my mchine has 1 gb ram and mora than 10 gb hard disk free...... wonder if you could give any idea or feedback................ cheers, maxkid Link to comment Share on other sites More sharing options...
frank1331 Posted August 17, 2006 Share Posted August 17, 2006 I would try to lower the dpi of the aerial. (Not sure if this is what you did to reduce the size originally) Also make sure the aerial is in a jpeg format, that will compress the size some. 40 mb is a huge file, I've never seen any photo that big before. Good luck Link to comment Share on other sites More sharing options...
jkletzien Posted August 17, 2006 Share Posted August 17, 2006 Maxkid, are you using this iamge as a map, or a background? If you are using as a background I would slap a low res version 200x400 into max and then replace with the high res version in post. If you are using as a map than you may have to do some juggling, breaking the image apart and using a blend material between low res and high res pieces of it - based on how close you get to various parts. A file of that resolution is not going to be friendly to your machine or your render times. Link to comment Share on other sites More sharing options...
