3DMax Memory Problem
Hi All
well just had my sysytem upgraded from 1GB to 3GB after moaning about how slow it was. The problem is that Max seems to be out of control now using all the CPU power ( 3.2GHZ ) and i can't even open a web page whilst it renders without it freezing up or slowing down.
Is there a way to limit max's memory usage so that I can run other applications as i was before the upgrade
cheers
take a peek in you boot.ini file located in c: (open it with notepad)
add /3GB on the operating systems bit (or if it exists, take it off)
eg,
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /3GB
this switch gives better handling of 2gb+ ram within windows.
eg,
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /noexecute=optin /fastdetect /3GB
Interesting tip. I suppose if you had 4GB of ram you would add /4G ?
  squeakybadger said:
Brian,
The /3GB switch is the only one. Its a Microsoft thing :)
It just allocates more memory to the programs, rather than reserving it for windows itself.
Xp64/Vista dont have a ram limit, and will use everything you can cram in them!
OK, I've heard of this 3GB switch before but never knew how to apply it. I'm glad to see it's so easy. Thanks.
well, up to a point;) Ram limitations are OS dependant and I've heard that Vista will be limited to a measly 128gb (of which, ATM, there are no consumer boards to support this much RAM) and for more than 128gb you'd need to go with one of the server OS's which are more than any of us want to spend on an OS.
  Baldrick said:
Be warned that it can make your system unstable - the results are a bit unpredictable. I've tried it on some workstations with success and others where it completely screwed the system and needed an OS reinstall... :(
quoted for agreement ~ I was asking the tech guy @ Boxx about this the other day and he nearly shite a brick! For peace of mind, and as Matt recommends, I'd stay away from the switch and wait for Vista and max 9.
well the latest update it that the 3gb made the comp very unstable so we took out 1gb and its working much better. Bearing in mind though that im using a standard NEC desktop maching at work, i tend to bring in my alienware laptop from home as its quicker.
oooh for a proper workstation!!
