3d studio max 8 error
Hmm.. I would say you would need to make a new scene and merge the objects from your old scene .. of course, there might be problems with the object geometry itself.. so do a STL check modifier first to see if the objects are alright.. that should help I guess..
umm.. Dont merge all the objects at the same time.. one at a time.. then you can isolate the object which causes this.. or maybe the light or materiel too..
EDIT: The next time you try this have the task manager open and check out which of the processes peaks just before the render crashes..
