maurocan Posted August 22, 2006 Share Posted August 22, 2006 hi everyone, i attach an image i am working on. the thing is i can´t get to disappear those grains all over the image. i does not look as clear and sharp as it should. i am working with max 8 with the following parameters: irradiance map: medium, 90-30 light cache: subdivisions: 2000 QMC sampler´s noise: 0 please any help or ideas ! bye Link to comment Share on other sites More sharing options...
Msamir Posted August 22, 2006 Share Posted August 22, 2006 Do you mind sharing the material settings of the curtains because they look great. Link to comment Share on other sites More sharing options...
lone Posted August 22, 2006 Share Posted August 22, 2006 well the grain could be many different things......ok....1st of all....use high quality in ur irradiance(i don't like irradiance, i like more QMC is more real) then check ur light(s) subdiv.......if that doesn't works could be the sample size of the light cache BTW the noise sampler should be over 0.....just a bit over... keep working Link to comment Share on other sites More sharing options...
BrianKitts Posted August 22, 2006 Share Posted August 22, 2006 make sure your "white" walls and ceiling aren't pure white (RGB = 255,255,255)... grey it up a couple ticks, vray doesn't interact well with the pure white. Link to comment Share on other sites More sharing options...
maurocan Posted August 22, 2006 Author Share Posted August 22, 2006 hey, thank you all, i am trying all these ideas but i can´t get it ok... i will post the curtains in a while, thnks!! Link to comment Share on other sites More sharing options...
