erickdt Posted August 22, 2006 Share Posted August 22, 2006 I am having serious issues rendering with VRay. I am doing a relatively simple scene at a low resolution (800x600) and it is taking insanely long to render (in excess of 30 minutes). I need to render 4 different views of this scene as well as 4 of another similar scene by tomorrow. I dont know if its my ir map settings or what (btw the settings are the low preset with 30/20. Irradiance map is the first bounce light cache is second, the noise threshold in qmc sampler is .01). Someone please help me!!!!! Link to comment Share on other sites More sharing options...
mikegeng Posted August 22, 2006 Share Posted August 22, 2006 how much is your glossiness? Link to comment Share on other sites More sharing options...
erickdt Posted August 22, 2006 Author Share Posted August 22, 2006 I'm not sure where can I find the glossiness setting? Link to comment Share on other sites More sharing options...
mikegeng Posted August 22, 2006 Share Posted August 22, 2006 i think it is in the material editor,when you use the VRayMtl, it appears below the Reflect and the Refract,the default value is 1.0 Link to comment Share on other sites More sharing options...
erickdt Posted August 22, 2006 Author Share Posted August 22, 2006 Oh... I know what you mean now. I have several different materials with a variety of different levels of glossiness or no glossiness at all. None of the subdivisions for that glossiness are higher than 8. Link to comment Share on other sites More sharing options...
corwin Posted August 22, 2006 Share Posted August 22, 2006 If your using alot of glossy materials go with adaptive qmc antialiasing ( i usually set at 1/3 for testing), adaptive subdiv can take forever with lots of glossys. hope this helps. Link to comment Share on other sites More sharing options...
bayvan Posted August 22, 2006 Share Posted August 22, 2006 Another thing that should help for the glosy is to turn on use light cashe for glosy rays in the light cashe rollout. Best regards, bayvan Link to comment Share on other sites More sharing options...
