hrvojezg00 Posted August 23, 2006 Share Posted August 23, 2006 I am trying to make the floor of a handball cort, so how do I apply both wood and cort lines? Link to comment Share on other sites More sharing options...
Camby1298 Posted August 23, 2006 Share Posted August 23, 2006 Which application are you using?? You could make a blend map from photoshop or use simple geometry and apply a material. But then again it depends on the application you are using. Link to comment Share on other sites More sharing options...
kippu Posted August 23, 2006 Share Posted August 23, 2006 easiest way would be to model the court lines and give them the different material, as brian mentioned Link to comment Share on other sites More sharing options...
hrvojezg00 Posted August 23, 2006 Author Share Posted August 23, 2006 you missunderstood me.first I apply wood floor material, and now I want to get the cort lines on that wood Link to comment Share on other sites More sharing options...
hrvojezg00 Posted August 23, 2006 Author Share Posted August 23, 2006 I will probably do it that way.thnx Link to comment Share on other sites More sharing options...
erickdt Posted August 23, 2006 Share Posted August 23, 2006 I would probably make the texture in photoshop. That would be the least time consuming way to do it and it would be easy to change and update. Link to comment Share on other sites More sharing options...
notamondayfan Posted August 24, 2006 Share Posted August 24, 2006 or model the lines as geometry in your floor, then apply a different material id to the lines. Link to comment Share on other sites More sharing options...
