nangkri Posted January 22, 2004 Share Posted January 22, 2004 hi all, i just want ask any one, how we can make fast for use radiosity in rendering proces,mybe the setting. coz everytime i use radiosity tecnique, igot aproblem with my machine (P4 2.6 Ghz, 512 Mhz). the process is to long (verry long), :ngesleep: maybe some one have a tecnique (setting) for this problem. thanks before.... best regards nangkri Link to comment Share on other sites More sharing options...
William Alexander Posted January 22, 2004 Share Posted January 22, 2004 nangkri, -1 Mesh processing size. Start out large 1/10 or larger than the structures largest dimension, for example. Reduce the size to meet your desire results. -2 Use lights that produce radiosity sparingly. If an indoor scene has 100 light fixtures, use an area light to represent the full amount of illumination. -3 Refine iterations- use it after getting the best results from previous suggestions. Start with low numbers and work up. -4 Filtering- very useful for quick results. However too large of a filter greatly decreases the radiosity effect, flattening out your image. -5 Regathering- use only as needed. You need to get a feel for rays per sample and how much more time it is going to take. The filter radius if set to large will decrease the radiosity-contrast. -6 Don't be afraid to use the light painting feature to correct or adjust poor areas. -7 if all else fails use photoshop with what you can produce in a given amount of time. rgrds WDA Link to comment Share on other sites More sharing options...
nangkri Posted January 22, 2004 Author Share Posted January 22, 2004 thanks WDA, for the info..... i'll try that and post my image tray soon as posible... sorry for my english best regards nangkri Link to comment Share on other sites More sharing options...
