tecton3d Posted August 24, 2006 Share Posted August 24, 2006 Alright, i just unwrapped this beaute, plugged it into my Quadro3400, and am getting a subtle ghosting within Max7 from windows that I have minimized, closed, or moved... even windows relating to the Max GUI such as a render frame, env & effects, etc. It is the worst when I go from a website back into Max because that leaves remnants of the text from said website in my max viewports which is totally annoying and distracting I was running seemingly old Maxtreme drivers (sorry, didn't notice what version) and thought that was the problem so I downloaded the latest (Maxtreme 8.00.03) from the Nvidia website, uninstalled the old > restart > install new > restart > open Max and the same ghosting is happening. ok, perhaps the Maxtreme drivers are causing the problems... so I downloaded the non-Maxtreme driver for xp32 > uninstalled maxtreme > rebooted > installed: ForceWare Release 90 Version: 91.36 > open Max again and still ~ the same thing is happening!!! any advice on what I should do? The new Apple 23" displays are plug n play so there's no software I can install from that end to reify the problem... or is there? has anyone else had issues with the Cinema HD Displays? ~ specifically the 23"? thanks ahead of time edit: just realized that the ghosting is also happening within the Firefox interface Link to comment Share on other sites More sharing options...
BrianKitts Posted August 24, 2006 Share Posted August 24, 2006 I'm assuming since you checked which maxstream drivers you are using , that you are telling max to use them for the graphics mode. Anytime I log into my work computer from home using remote desktop, I have to boot max using the "change graphics mode" and put it into software mode instead of direct3d. If I forget to change it back the next day when I get to work I get something extactly like what you're describing. I guess I'm saying make sure you've got your graphics mode set right before you check anything else..... Link to comment Share on other sites More sharing options...
tecton3d Posted August 24, 2006 Author Share Posted August 24, 2006 thanks for the reply. I'll go through un/installing the maxtreme drivers again and see if somehow I missed changing graphics mode (don't think I did, but it's worth a try) ... we'll hope that cures it:D you changed your Avatar ~ cute:p I've a beagle too ... his name's "William Wallace"... or Willie for short;) Link to comment Share on other sites More sharing options...
csirison Posted August 24, 2006 Share Posted August 24, 2006 search for this display window-driver "WinACD-0.4.5" may be newer version has been released.... let me know also Link to comment Share on other sites More sharing options...
tecton3d Posted August 24, 2006 Author Share Posted August 24, 2006 search for this display window-driver "WinACD-0.4.5" may be newer version has been released.... let me know also thanks for the help! digging through my hd's looking for that file but nothing as of yet. an update: this is also happening on the desktop. with the background set to black, I couldn't notice but with it @ about 75% grey, I can see the outline of the previously activated window... Link to comment Share on other sites More sharing options...
tecton3d Posted August 24, 2006 Author Share Posted August 24, 2006 go there :> http://www.chait.net/index.php?p=46 done ~ downloaded the 2nd listed version for the 23": as per directions lower on that page: Display Properties => Advanced => Monitor Tab => Properties Driver Tab => Update Driver => Install from specific location + next Don’t search… + next => Have Disk => Browse… => {{Find the INF file…}} … accept ... after all that I get : "the wizard could not find a better match for your hardware than the software you currently have installed... a. keep current software installed b. search again" here is a screencap of what's happening on the desktop (I hope it shows up) a shot of my desktop icons hanging out in the max interface: Link to comment Share on other sites More sharing options...
csirison Posted August 24, 2006 Share Posted August 24, 2006 http://prdownloads.sourceforge.net/winacd/WinACD-0.4.5.zip?use_mirror=umn if you want ill can email you the display software Link to comment Share on other sites More sharing options...
tecton3d Posted August 24, 2006 Author Share Posted August 24, 2006 http://prdownloads.sourceforge.net/winacd/WinACD-0.4.5.zip?use_mirror=umn if you want ill can email you the display software thanks for all your help! I've downloaded the file and know it works because i can adjust the brightness but it has yet to get rid of the weird artifacting. thanks again csirison:D Link to comment Share on other sites More sharing options...
tecton3d Posted August 25, 2006 Author Share Posted August 25, 2006 just an update, the onscreen "wierdness" that I'm getting is almost like a burn-in type of effect. If I have, outlook or photoshop or anything with strong contrasting colors to my background (dk grey) the contrasting color is left after I close the window. If I can't find something tonight I'm giving Apple a call first thing in the morn. Link to comment Share on other sites More sharing options...
Ky Lane Posted August 25, 2006 Share Posted August 25, 2006 Personally, id say your screens buggered. Have you tried another to test? Link to comment Share on other sites More sharing options...
tecton3d Posted August 25, 2006 Author Share Posted August 25, 2006 just the one I'm trying to replace the apple with which works fine and has never had such problems fwiw: it's a samsung 173p cheers Link to comment Share on other sites More sharing options...
Ky Lane Posted August 25, 2006 Share Posted August 25, 2006 If the samsungs fine, then apple sent you a lemon... ...how ironic. Link to comment Share on other sites More sharing options...
csirison Posted August 25, 2006 Share Posted August 25, 2006 Same problem here, the ghost stalking me home! When the display brighten up they will be gone but when it gets dark-grey they will show up. seems like the emitting diode have some phisical limit, when the 23" are left with the same screen for a while the diode likely to get saturated and cant emit the correct color for a while. I think all LCD behave the same, they cant refresh as accurate as fast as CRT. wait a while and you will also notice that the 4 corners of the monitor show some strange color... I might be wrong about the theory but i just get familiar with it, cant leave withou it. Link to comment Share on other sites More sharing options...
