only3d Posted August 26, 2006 Share Posted August 26, 2006 hi evrybody, long time no here in the forum but now im back w 2 q's- 1- how do i cancel the auto-refresh of the 2d drawings? its really annoying and time-consuming 2- im having problems w the "moldings" wall accss. im getting a 'GDL DEBUG' error which i never got before. fyi- its a fresh installation on a new pc (V8) and the file is an import dwg. any ideas? tnx in advance Link to comment Share on other sites More sharing options...
bricklyne Posted August 26, 2006 Share Posted August 26, 2006 I would recommend that you upgrade to either ArchiCAD 8.1 or version 9 ( or even better version 10). Version 8 was full of tons and tons of bugs such as the GDl error you seem to be having which is why they quickly released version 8.1 shortly afterwards as a free upgrade. 1) for the Auto-refresh question, change the setting in your Section/Elevation line settings from 'Autorebuild' to 'Manual Rebuild' or 'Drawing' ( if you want to de-link it from the model, that is). That will make the sections and elevations only update when you tell them to, and not all the time. 2) I'm not sure what's giving you that GDL debug error per se, but like I said, it is probably an error related to the fact that it is version 8.0. You should try to get either version 8.1, 9.0 or 10, to avoid those kinds of errors. Link to comment Share on other sites More sharing options...
only3d Posted September 3, 2006 Author Share Posted September 3, 2006 hi brick and tnx 4 your reply. about your 2nd tip- i kinda handled it although i m working om getting archicad10 edu version. it seems really powerful and much improved. about your 1st tip on the other hand u didnt really get what i meant which is how 2 cancel the auto-refresh of the plan and not the elevations\sections dwgs, if that is possible at all. so is it? Link to comment Share on other sites More sharing options...
