Large scenes and small problems...
atp-design
Hi
Is the Vray the best choice for rendering very large and complex scene?
I am an architect and i'm working on a big project contain town houses,towers,shopping mall,landscapes ,roads,trees, and more...
I would like to render my project with natural lighting effects in short time and good quality , can you help me ? which render engine should i use???
I usually use Final-render stage-1 , but the image rendered in 24 h !!!
is it possible in Vray to do it in less time?
Well it depends on alot of things, like the dimensions of the rendering etc...
If you're right in the middle of a project, I would suggest you don't switch render engines, wait till it's done then if you still find it to be inadaquate, then switch...
I can give you a tip I think. Any render engine work in same ways... more or less options but all of them do it in similar ways. The trick for scenes with a lot objects some times is the materials. Do give a high profile to a material that will be appear so far because no one will see the difference... but the render engine yes!!! Other solution would be to split the scene in layers. A layer with the objects so far and other one for near things. Obviously the near you would use a high parameters and the other a low profile and fix it with a little bit blur in Photoshop. Then... you know join its in Photoshop and Voila!!
Good luck!
how can i separate objects during an animation? in some cases one object moving in depth and mask behind others. so how should i render a scene in 2 or more files as different layers for composing in a software like aftereffect ? i dont underestand where the z-depth data could be save?
