Ricardo Eloy Posted August 27, 2006 Share Posted August 27, 2006 Well, this may sound weird, but... The new VRay 1.5 has the option to work with real world units for lights (ie, watts, lumens, etc). Not to mention the new PhysicalCamera. The question is:3ds max uses, by default, 1 unit=1 inch. Assuming I'm working in metric system, is that the right setting or should we change that in order to use these new features? Link to comment Share on other sites More sharing options...
imgumbydammit Posted August 27, 2006 Share Posted August 27, 2006 Someone may (will ?? ) correct me but I wouldn't think that lumens or watts are in any way linked to distance standards like inches or millimeters so it shouldn't make any difference as to what your world measurement standards are set to... IGD Link to comment Share on other sites More sharing options...
vishesh_12 Posted August 28, 2006 Share Posted August 28, 2006 yes i agree with imgumbydammit completely. you can choose any unit settings as u want in max [ like inches, feet, mm, meters etc... ]. as long as you are making the scene according to the real world scale, it won't affect the lights at all. Cheers !!! Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted August 28, 2006 Author Share Posted August 28, 2006 So, keep working with System units as 1 unit = 1 inch and things should work, right? Link to comment Share on other sites More sharing options...
vishesh_12 Posted August 28, 2006 Share Posted August 28, 2006 yes, it will work Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted August 28, 2006 Author Share Posted August 28, 2006 Ok... I just thought that since VRay now uses Watts and Lumens for lighting, maybe there was a "correct way" to work your units if you use meters/centimeters/whatever metric unit you like. Thanks for the input! Link to comment Share on other sites More sharing options...
