Problem with vray and backburner
pradipta
I am facing an unique problem with vray network rendering. i am using 3dsmax 8 and vray 1.47. in rendering server vray is not rendering the final render after calculating the LC and IR map passes. What can be the reason behind this? while rendering on single machine the rendering is coming as usual. Thanks in advance for any advice.
Brian, i have not checked the "do not render final image" in render setting. i rendered the same file with same rendering setting on standalone machine, and it is rendering. i kept all the textures in the individual machines and output files are also getting saved in the respective machines. i have no clue why this is happening. Thanks Brian for your response.
