Refraction Anomolie
Ky Lane
Could be the background image. Does the glass have a thickness? I remember reading somewhere that Vray has a real tough time doing refractions through a single pane. Try giving the glass a minute thickness, say around .05" or .1"?
I had the near exact same problem and adding in thickness fixed it. Hope this helps.
Yeah its a lofted rectangle...
I still cant get it to nick off...very annoying..
also check your glass material has "reflect on back side" ticked.
I had a similar problem when trying to render glass as a plane, although i know you havea lofted rectangle, it could still be the normals on the back plane facing the wrong way.
Id make this the glass thickness is correct because i think it it is REALLY thick then refraction plays a bigger role (just incase that is it)
