Viewer for Panoramic Images
nisus
i dont know what you mean exactly. do you mean like 360 quick time movies, where you click and drag so it appears like you are rotating on the spot?
if so check this out http://plugins.marclorenz.com
its a plugin for max, and is the easiest thing ive ever used, and has pretty good results.
or do you mean like you have a single image, but really wide panoramic shot? almost too wide to view on screen?
if so, you'll prob need some interactive web application, such as flash. try looking through http://www.flashkit.com.
hope that helps,
deano!
Hi Dean,
Tnx for your quick reply. I meant the 360 degrees images. I'll check out the link you gave me.
In the mean time I've found that max has a renderer and exporter. Pitty is, it doesn't seem to work with network rendering. Any one got a clue on how to surpass this? Tnx
nisus
Well, yeah... but I would prefer to render out the files in the network, so my workstation can be used for other stuff... Also, the panoramas render 6 images (every face of a box), which is faster with 6 machines ,-)
So any tips are welcome ,-)
nisus
I know that max can do the panarama, but what you can do with the spherical camera is render it with backburner and use the "split scanlines" option, then you bring in the spherical image as an environment map and then use the max panorama exporter on your local machine. It ends up being much quicker.
