seamus Posted August 29, 2006 Share Posted August 29, 2006 I've started using vray 1.5 and after watching Christopher P Nichols DVD I've tried using gamma correction. I've found that the setting options are different - "multiplier, Inverse gamma and gamma". I have kept all of these values at 1 and instead I have changed the gamma within the preferences in max (see attached image). This gives good results and seems to work fine however I have noticed that when I import a bitmap through the material editor the preview display of the bitmap is a different shade to the photoshop version and to the version displayed on the material editor after import. Am I doing this incorrectly? What is the best method using vray 1.5? Link to comment Share on other sites More sharing options...
bayvan Posted August 29, 2006 Share Posted August 29, 2006 If i'm not mistaking the output should stay at 1 Sory for my English Best Regards, bayvan Link to comment Share on other sites More sharing options...
seamus Posted August 29, 2006 Author Share Posted August 29, 2006 I tried that. It seems to affect the images when I save them from the frame buffer and open them in photoshop - they end up darker. This works fine with the setting at 2.2. Link to comment Share on other sites More sharing options...
