steveblake Posted August 30, 2006 Share Posted August 30, 2006 I'm very interested in getting some images together that have a wireframe overlay and wondered if anyone here had some suggestions? The superb looking ArchInteriors have some samples on their site that show the sort fo thing I mean - you get the texture, shadows etc AND the wires, with some of the objects semi transparent. A mult-pass render perhaps? but how do you render hidden line removal wireframes 3dsMax? http://www.evermotion.org/shop_display_item.php?item=159 like this: or this: cheers Link to comment Share on other sites More sharing options...
steveblake Posted August 30, 2006 Author Share Posted August 30, 2006 sorry if it's a ultra-basic question - i normally work in Lightwave and Maya Link to comment Share on other sites More sharing options...
chuck Posted August 30, 2006 Share Posted August 30, 2006 It looks like there are two passes. One is a rendering with lighting and a plain white material applied. The other is just a standard wireframe rendering. The wireframe doesn't have any hidden lines. In max, under the scanline renderer you can "force wireframe" which will give you black lines and a white background. From the same view, just render another pass with a white material and the lighting you want. In photoshop lay the wireframe over the other. Change the wire frame's layer to "multiply". You can then mess with the opacity/brightness etc of that layer to make the lines gray not black. Chuck Link to comment Share on other sites More sharing options...
steveblake Posted August 30, 2006 Author Share Posted August 30, 2006 thanks chuck that'll be it.. I was thinking of maybe using the old david gould plugin Illustrate, but this method looks fine. Thanks for the help. Link to comment Share on other sites More sharing options...
Vince Paske Posted August 30, 2006 Share Posted August 30, 2006 You could also clone your objects and apply a lattice modifier to them, use "struts only" and adjust the radius to smooth out the lines. This will give you a hidden-line look vs. the "x-ray" look. Link to comment Share on other sites More sharing options...
notamondayfan Posted August 30, 2006 Share Posted August 30, 2006 theres also a hiddenwireframe plugin on scriptspot that renders hidden wires easily in scanline Link to comment Share on other sites More sharing options...
steveblake Posted August 31, 2006 Author Share Posted August 31, 2006 thanks notamondayfan, yeah I noticed this one seems to only render static images tho... You could also clone your objects and apply a lattice modifier to them, use "struts only" and adjust the radius to smooth out the lines. This will give you a hidden-line look vs. the "x-ray" look.nice idea I'll give it a try... Link to comment Share on other sites More sharing options...
