ZFact Posted August 30, 2006 Share Posted August 30, 2006 Hi All; Can anyone help me with the attached elevation. I am having some difficulty modelling this roof. It has a sloping eaves and sloping ridge. Both sloping in opposite directions. Nightmare or what? Any suggestions welcome. Link to comment Share on other sites More sharing options...
AJLynn Posted August 30, 2006 Share Posted August 30, 2006 You're a Cinema4D user, yes? No problem - make three edges with linear splines and loft them with linear interpolation, then get the lines using a texmap in Flat mode. Very quick-and-dirty example attached. Link to comment Share on other sites More sharing options...
SunGlare Posted August 30, 2006 Share Posted August 30, 2006 It looks like some BMI aplication output. If you can ask them for model, or source file. At least architect should know whats going on. Dont assume anythig. From my experience surfaces that opposite edges are not pararell in space are total no-go for cheap architecture like multifamily housing. Think about construction cost. So I would revise the plans with architects, if thats the case, to make surethis is what theay want. Maybe other elevations will solve the mystery of this roof, I'm 95 % that the roof slope is flat(its not nonuniform surface), but only roof eaves are cuted tricky. Link to comment Share on other sites More sharing options...
Brian Smith Posted August 30, 2006 Share Posted August 30, 2006 This is not difficult to create in 3D at all. Simply create closed plines in CAD, import the linework, use EditSpline to attach all the splines, go to vertex subobject mode and position the vertices as necessary, and collapse to an editable mesh. You can extrude the edges or use a loft to create the fascia. Link to comment Share on other sites More sharing options...
ZFact Posted August 31, 2006 Author Share Posted August 31, 2006 Anyone know how this would be achieved in vectorworks or autocad Link to comment Share on other sites More sharing options...
3D_IC Posted September 1, 2006 Share Posted September 1, 2006 you can create the roof as a surface Link to comment Share on other sites More sharing options...
