mskin Posted August 31, 2006 Share Posted August 31, 2006 Does anyone know a way to shade an xref (autocad 2007)? I want a reference to shade similarly to the way it shades during refedit mode, but when im working on the drawing normally. i seam to recall some slide bar that changes the references appearance..... thanks Link to comment Share on other sites More sharing options...
neko Posted August 31, 2006 Share Posted August 31, 2006 when you say 'shade' you really mean transparent, correct ? i like your idea, and i tried to find something new in 2007 that might do that, but i can't seem to find anything. my only suggestion might be to change all the colours of the xref layers to a greytone (in the assembly drawing) and make sure that the VISRETAIN variable is set to '1' - which means it can be independent from the original xref. hope that helps cheers Link to comment Share on other sites More sharing options...
mskin Posted August 31, 2006 Author Share Posted August 31, 2006 yes, i mean transparent - or partially transparent. Usually i do just change all the colors to a 243 or 244, but there is so much information on the drawing that its extremely muddy when doing that. Link to comment Share on other sites More sharing options...
neko Posted August 31, 2006 Share Posted August 31, 2006 might have to wait for autocad 2008 then ...... Link to comment Share on other sites More sharing options...
