vodka79 Posted September 1, 2006 Share Posted September 1, 2006 I want to add some entourage i bought from got3d.com They are fantastic, however the surroundings are blury, how do i add them in PS without the blury surrounding the entourage? Link to comment Share on other sites More sharing options...
frank1331 Posted September 1, 2006 Share Posted September 1, 2006 If they came with an alpha channel, you need to go into photoshop and lay the two images together. Select the alpha channel with the magic wand, then goto the image layer, select the inverse, and delete it. I have the same issue with image entourage I get from another company. Hope this helps. Link to comment Share on other sites More sharing options...
Brian Cassil Posted September 1, 2006 Share Posted September 1, 2006 Actually, the proper way to use the alpha channel for masking out the "blurry" area is to create a new channel in the color image, then paste the supplied alpha channel into that new channel of the color image. Ctrl click the new channel, go over to your layers tab and copy it out of there and into your scene. This will prevent artifacts (jaggies, halo) that would appear from using the magic wand. You could also create a layer mask, but that's a bit longer of an explanation. Link to comment Share on other sites More sharing options...
jophus14 Posted September 1, 2006 Share Posted September 1, 2006 You might also try going to "Select" and choose "Load Selection" from the drop down menu. This should give you the alpha automatically. Link to comment Share on other sites More sharing options...
DennisHolland Posted September 1, 2006 Share Posted September 1, 2006 Or feather the selection and contract a pix or two. Gone jaggies... Dennis Link to comment Share on other sites More sharing options...
STRAT Posted September 2, 2006 Share Posted September 2, 2006 Actually, the proper way to use the alpha channel for masking out the "blurry" area is to create a new channel in the color image, then paste the supplied alpha channel into that new channel of the color image. Ctrl click the new channel, go over to your layers tab and copy it out of there and into your scene. This will prevent artifacts (jaggies, halo) that would appear from using the magic wand. great tip Brian, i never considered that before Link to comment Share on other sites More sharing options...
