vodka79 Posted September 3, 2006 Share Posted September 3, 2006 Please give me your C & C. using sketchup n maxwellrender. I don't know where or how i can improve to look like those professional renders shown here. Link to comment Share on other sites More sharing options...
darkblue_wire Posted September 3, 2006 Share Posted September 3, 2006 hi i am a v-ray user so i don`t know if i could help but i have tried maxwell for sometime u could have very nice result using maxwell light seetings not right at all u may need to visit evermotion website & download maxwell exterior tutorial i may suggest also interior tutorial u have to care more about environment ( background , people ,even colours ....) u need to practice much more visit : http://www.evermotion.org http://www.allusions.com http://www.3dtotal.com http://www.vrayinfo.com i hope that i don`t have words mistakes for the websites best regards Mohamed aref Link to comment Share on other sites More sharing options...
Thiago de Andrade Posted September 3, 2006 Share Posted September 3, 2006 It looks shadowless. I don't know how you set the lights, but a good sun light appears to be the begining of the improvement... Link to comment Share on other sites More sharing options...
Geoffc Posted September 5, 2006 Share Posted September 5, 2006 can you change the angle also, so the frame isn't half asphalt? Link to comment Share on other sites More sharing options...
gods418 Posted September 5, 2006 Share Posted September 5, 2006 the building or the structure is half seen unless your focus is the basketball court??? also theres no shadow... Link to comment Share on other sites More sharing options...
vodka79 Posted September 5, 2006 Author Share Posted September 5, 2006 Thanks all for the tips. I got this angle shot because the building is actually long, and this shot captures 3/4 of it together with it's ammenities like the little garden rest area and the basketball court. It's already quite a distance to capture this shot; and if i move further away to capture the entire building there will be plenty of white empty spaces below and the building and it's ammenities will be much smaller. Link to comment Share on other sites More sharing options...
Geoffc Posted September 6, 2006 Share Posted September 6, 2006 what is the focal length of the camera lens you're using? can you go for more of a wide angle lens? just a thought. it does cause for some bending of the vertical surfaces at each end of the picture though. Link to comment Share on other sites More sharing options...
vodka79 Posted September 7, 2006 Author Share Posted September 7, 2006 wouldn't changing the focal length means smaller image? It is supposed to printed on A3. I'm thinking as well how to reduce the bottom half of the asphalt. Using a eye level of 1700. Link to comment Share on other sites More sharing options...
Geoffc Posted September 7, 2006 Share Posted September 7, 2006 If you went to a wide angle lens, ie, 28mm, 20mm, or even lower, you could move the camera closer to the building, yet still being able to see the same abount of the structure while lowering the amount of asphalt seen. BUT, like I said, the problem with wide angles is the pinching of the vertical building elements that can occur at each far end of the view. Link to comment Share on other sites More sharing options...
