mr. a Posted September 7, 2006 Share Posted September 7, 2006 Hi everyone, I am trying to render a scene in an all white material while still showing the wireframe edges for all the objects as is done on the Evermotion site: http://www.evermotion.org/shop_display_item.php?item=22 How do I do this in Vray? Thanks. Link to comment Share on other sites More sharing options...
FlytE Posted September 7, 2006 Share Posted September 7, 2006 Create a grey material. In the diffuse map slot put an "Output" map and in the outputs map slot put a "VrayEdgesTex" map. You may need to bump up the actual output level (from 1.0 to like 5.0) in the output maps properties to get the wireframe to display the way you want.... Link to comment Share on other sites More sharing options...
mr. a Posted September 7, 2006 Author Share Posted September 7, 2006 Excellent ! Much easier than duplicating all materials and applying a wireframe material Thanks. Link to comment Share on other sites More sharing options...
alikashan Posted September 9, 2006 Share Posted September 9, 2006 very helpful and easy tip thnx:cool: Link to comment Share on other sites More sharing options...
