Vray material problems in vray free
ssstrutz
Hello all,
I am new to vray and I am using the free downloaded version with autodesk viz4. Is it possible to use vray materials with this version of viz and vray free? The ones I have downloaded come up with some sort of error and I am unable to use it when I insert through the material browser.
Thanks,
Scott
Thanks for the messages.
That is too bad. Do you have any suggestions as to materials that would work best with vray free? Are there any special settings that would help my images look more realistic? It is kind of difficult to decide if I would like to purchase the program if I can't get a real idea as to how the images can look.
Also, am I not finding the vray lights, or do they not come with the free version also?
Thanks,
Scott
I much prefer the full version, but I have made due with only Vray free before.
The best you can do with vray free is use the vray map in standard max material reflection and refraction map slots. I think you can use it in the opacity slot as well.
Select the Vray shadow for the active shadow on the Max light shadow parameters. You can change the softness of the shadow edge my changing the Max light U and V size under the vary shadow settings on the light modifier panel.
The brazil HDRI map works to bring in HDRIs in.
Test your settings on small 160x120 renders and then do your final render in high res.
Have fun!
