Sergio_Pontes Posted September 8, 2006 Share Posted September 8, 2006 Hi, I imported a 3ds model in the Vue 5 Infinite and can't view it in viewport to adjust the cameras. This model is in cm. Exists some adjustment that I can make to solve this. The problem seems to be some adjustment of "clipping planes". Thanks Sérgio Link to comment Share on other sites More sharing options...
Bugga_Guy Posted September 9, 2006 Share Posted September 9, 2006 My assumption is that your scale is too big. Vue has a problem where it only uses world units - if you model is too big then you run into complications - you would have to manually scale your model down but unfortunatly there is no numeric indicator telling you by how much. Another way around it is to goto options and click "rescale and center" but by doing so you will have no way knowing what your scale is. If you built the model in 3ds max and then imported the model in, use the rescale world units modifyer and scale your model down. Link to comment Share on other sites More sharing options...
Sergio_Pontes Posted September 12, 2006 Author Share Posted September 12, 2006 Thanks! The problem is that my drawing is in centimeters. The stranger is that in meters 3ds is imported full of imperfections and also does not appear in viewport. The solution that gave here certain was to adopt an "intermediate" scale, 10 times bigger in meters and 10 times smaller in centimeters. Best regards, Sérgio Link to comment Share on other sites More sharing options...
