superdave Posted September 8, 2006 Share Posted September 8, 2006 Hey guys, I just recently got vray and have been playing with it alot. I am very excited and see alot of potentially great things being produced using it. But I have run into one massive problem that I don't seem to be able to resolve. The sence I am tring to render isn't very large and I am using RPC's in it. If I render a test at 640x480 it comes out fine, but when I increase the size to say 1600x1200 it starts out fine then in the middle of the final phase starts rendering out gray instead of the material color. I am going to attach an example of this to try and help explain. Please let me know if anyone has seen this before and might have some idea how to resolve it. Again this is not a huge scene and am wanting to produce some larger enviorments. Any Help would be appretiated. David Link to comment Share on other sites More sharing options...
Chad Warner Posted September 8, 2006 Share Posted September 8, 2006 IF you are using Viz, you have to either use the 1.46.15 build, or the 1.5 build. If you are using max, it seems like it could be a memory issue. Link to comment Share on other sites More sharing options...
superdave Posted September 8, 2006 Author Share Posted September 8, 2006 It is the 1.47.03 Version and I am using Viz. Link to comment Share on other sites More sharing options...
Chad Warner Posted September 8, 2006 Share Posted September 8, 2006 If you email Vray, they'll send you the older build for use with Viz. Otherwise, you can upgrade to the 1.5 version and it should work fine. Link to comment Share on other sites More sharing options...
superdave Posted September 8, 2006 Author Share Posted September 8, 2006 Is the 1.5 ready? They were having issues with it a couple of weeks ago. Link to comment Share on other sites More sharing options...
superdave Posted September 8, 2006 Author Share Posted September 8, 2006 When I render large images is when the render drops the maps. I am suprised no one else has had issues with this. I am reluctant to think that it is my machine. I am confident it is not, but could be wrong. I guess I will have to figure out the whole 1.5 version which requirs a dongle which I yet to recieve. Currently Running Dell Xeon 3.60 GHZ 3.59 GHZ 3.00 GB of Ram Chad thank you again for your help turns out it was the version of Vray that was causing the problem. Currently rendering massive images with no problems unlike before. Thanks Again! Link to comment Share on other sites More sharing options...
sofad Posted September 8, 2006 Share Posted September 8, 2006 i have this problem too and i use viz, i cant solve the problem but sometimes if i turn off all the previsualization of the materials in the material editor and in the scene it's seems to work better i think is a kind of a bug but i dont know i asked this question a few weeks ago too http://www.cgarchitect.com/vb/18253-error-render-vray.html Link to comment Share on other sites More sharing options...
jophus14 Posted September 9, 2006 Share Posted September 9, 2006 I'm using VIZ 2006 at work and I have to use Vray version 1.46.15 in order for my bitmaps to render correctly. It sucks. Link to comment Share on other sites More sharing options...
superdave Posted September 11, 2006 Author Share Posted September 11, 2006 I wanted to verify again what I found to resolve this issue. It does appear to be the version of V-ray based on everything I have heard and experianced so far. If anyone is having this issue I would suggest getting the 1.5 Version of V-ray, Chaosgroup can send you a software dongle so you don't have to wait until they get the hardware dongle to you. I upgraded last week and this resolved alot of my problems that I was having. Good Luck All Link to comment Share on other sites More sharing options...
