atp-design Posted September 9, 2006 Share Posted September 9, 2006 I am working on a meshe that created with mesh smooth modifier.i want to create some contour lines (horizental 2d sections) from it. by using section command spline created has a larg number of vertices that not easy to work later.how can make these contour lines with bezier splines that has a few vertices ? on other hand how can i optimize the high poly-segments curves using the minimum nuber of vetices and save the shape? Link to comment Share on other sites More sharing options...
Woody Posted September 9, 2006 Share Posted September 9, 2006 Can you post some screen shots of what you want to do with the mesh? Link to comment Share on other sites More sharing options...
atp-design Posted September 10, 2006 Author Share Posted September 10, 2006 ok , i tried to explain what i'm saying in these pictures.. i think if i could make the meshe with NURBS instead the meshe smooth modifier i would be able to make horizental section more accurate and simple results.. Link to comment Share on other sites More sharing options...
Woody Posted September 10, 2006 Share Posted September 10, 2006 Hi, I don't use nurbs at all, but here's one method I use to tidy up my mesh with. - see attached images. Hope it helps!!! Link to comment Share on other sites More sharing options...
atp-design Posted September 10, 2006 Author Share Posted September 10, 2006 thanks woody, but my problems is that, in the object i'm working on, edges are not in a same directions . let me to explain some things about project, i have a smooth mesh like airplane body but in vertical direction , this is skin of building that i want to create floor plans in each elevation, so i cut the body with a plane at specific level to make the boundry of floor plan. the result is ver complicated because it has numerous vertices! please help me how can optimize the contour lines? Link to comment Share on other sites More sharing options...
Brian Smith Posted September 10, 2006 Share Posted September 10, 2006 I believe the closest solution you can find would be to weld vertices within a specified threshold. Link to comment Share on other sites More sharing options...
atp-design Posted September 11, 2006 Author Share Posted September 11, 2006 ok, i had tried to weld vertices by various treshold size but the main shape changed .because some importonat points specialy in quadrants missed.also the spline separated into segments,...anyway reduction the number of vertices without any adjustments is not a good solution, i tried the optimize spline yesterday , it's not bad , but it has not enoght precision. Link to comment Share on other sites More sharing options...
vishesh_12 Posted September 14, 2006 Share Posted September 14, 2006 Lets say u got the spline using the section command. now the only problem u r facing is "How to reduce the number of vertices." 1. First right click the spline and choose properties. check Vertex Ticks. 2. now apply the Normalize spline modifier to the spline. 3. play with the Seg Lenth paramter to get the right settings u want. than u may need to adjust the spline a bit, specially on corners. it won't take much time to adjust it. hope it helps Link to comment Share on other sites More sharing options...
atp-design Posted September 14, 2006 Author Share Posted September 14, 2006 thank you Vishesh Bharara I did'nt know that normalize spl modifier is exist! thanks , but this modifier just reduce numer of vertices base on a distance ,so there is no control on it's positions. and final spline has smooth vertices it's probably deform the shape. i prefer spline optimizer yet, because you have more control and vertices are bezier. try it ,it's free to download. Link to comment Share on other sites More sharing options...
vishesh_12 Posted September 14, 2006 Share Posted September 14, 2006 i will surely try the spline optimizer. thanks for the info Link to comment Share on other sites More sharing options...
