rsanabria80 Posted September 11, 2006 Share Posted September 11, 2006 Hello, I'm new in this community, and I need help solving some final render illumination errors... I have a building, i'm using VRAY render engine, and i'm using for GI, an HDRI. When I render the scene, i get in some places (specially in 90 degrees angles) some weird noise that would probably simulate a shadow, but there shouldn't be any... I'm only using the HDRI as GI and have no other lights in scene... I can send you the image if you need it... please leave me your mail, o tell me how can i upload the image at thes website... Thank you very much for you help... Looking forward to hearing from any of you soon! Ricardo Link to comment Share on other sites More sharing options...
BrianKitts Posted September 11, 2006 Share Posted September 11, 2006 you just need to increase the values on your render settings to clear that up. If you post your settings we could tell you whats wrong. Link to comment Share on other sites More sharing options...
rsanabria80 Posted September 12, 2006 Author Share Posted September 12, 2006 Hello BKittsARC, thanks for your reply... I'm attaching my Vray Settings... please let me know if you need anything else, and if you get to know what the problem is... Thanks Ricardo Link to comment Share on other sites More sharing options...
tejalvirkar Posted September 12, 2006 Share Posted September 12, 2006 hey! though i am also learning vray think that could help u out with this. Just put the check box off of clam out below Exponentional in color mapping. & check on the refl/refrac in enviornment.Also in GI caustics uncheck reflective. I hope these changes would make a positive difference. Let me know what output finally u got. cheers Link to comment Share on other sites More sharing options...
atp-design Posted September 12, 2006 Share Posted September 12, 2006 hi, send your scene file if it's possible , i'll try to check it Link to comment Share on other sites More sharing options...
rsanabria80 Posted September 12, 2006 Author Share Posted September 12, 2006 Thanks Ali, i tryed your changes but didn't have better results... What i did was to change the built-in preset for my irradiance map, from medium to high.... that work perfectly... that was the problem... so if anyone have the same error, try doing that, since that's what causes it... Thank you all Ricardo Link to comment Share on other sites More sharing options...
rsanabria80 Posted September 12, 2006 Author Share Posted September 12, 2006 Thanks Tejal... Link to comment Share on other sites More sharing options...
atp-design Posted September 13, 2006 Share Posted September 13, 2006 Just turn on "CHECK SAMPLE VISIBILITY" good luck Link to comment Share on other sites More sharing options...
