Josh1587140445 Posted May 21, 2003 Share Posted May 21, 2003 Here is a model that I am currently working on. If anyone can give me an suggestions on how to improve the quaility would be great. Thanks in advance. Radiosity setting: Quality - 85% Refine Iterations - 5 Filtering - 3 Meshing - 1'-6" Lighting setup is a sky dome with an Omni to light it, with the daylighting setup for the building. Link to comment Share on other sites More sharing options...
lucidchris Posted May 21, 2003 Share Posted May 21, 2003 I wouldn't be using an omni light with a Radiosity daylight system. The whole idea of radiosity is to create ambient light by bouncing light from different surfaces. Therefore an omni light is not required. If yoiu remove the omni and cannot see the building you then need to work on your Daylight settings Good Luck. Chris. :angeuhoh: Link to comment Share on other sites More sharing options...
