sleepphase Posted September 14, 2006 Share Posted September 14, 2006 It's my first post and I'm a beginner and trying to learn on my own. I am using 3d max and vray renderer, i've had this problem where the bottom parts have these white higlights which is really unusual i'm really intersted in making these rectilinear forms and creating aesthetically pleasing compositions any critiques and advice are welcomed... Link to comment Share on other sites More sharing options...
blade911 Posted September 14, 2006 Share Posted September 14, 2006 hey thr, nice forms.. postin ur settings wud help others to help u more.. these glows usually come with low irr settings.. switch to medium or high or custom settins to impove on the quality.. check with ur anti aliasin filter, noise thresholds too.. stick on to catmull rom or michell netravali... correct me if im wrong all gurus! cheers Link to comment Share on other sites More sharing options...
sleepphase Posted September 14, 2006 Author Share Posted September 14, 2006 here are my settings Link to comment Share on other sites More sharing options...
gods418 Posted September 15, 2006 Share Posted September 15, 2006 you can change the brightness on the gamma corection on the virtual frame buffer of vray......... hope this helps.... Link to comment Share on other sites More sharing options...
only3d Posted September 19, 2006 Share Posted September 19, 2006 not sure but possibly its the 'saturation' value under 'indirect illumination' take it down to 0.1 0.2 even if it doesnt help u should do it anyways (helps when u use very colourfull objects) good luck Link to comment Share on other sites More sharing options...
sleepphase Posted September 19, 2006 Author Share Posted September 19, 2006 i change the setting to high ...the artifacts at the bottom are gone...longer render time... i had it at medium (animation settings) Link to comment Share on other sites More sharing options...
