jtiscareno Posted September 15, 2006 Share Posted September 15, 2006 I have three non related max questions so any help in all or some is good: 1. Is there a way to "purge" a max file like in autocad? 2. I am stuck in animating the slice plan in the slice modifier using the manual set key method, I have been able to animate using the auto key. I did a search and followed the simple the simple directions to apply modifier, got to slice plan, tun set key, move plan to bottom, set key, move plan to top, set key and bingo...but after this when I play the animation it does NOT move the plan up, only if I use auto key can I animate the plan...am I doing something worng, missing a setting??? 3. I can not get the "ghost" effect in the script for rpc silhouette from http://www.3idee.nl/3d/html/layout.php to work anymore to make the rpc have a solid color, I can make them transparent since we moved to max8 and vray 1.47, is it the script or something else. Thanks for all the help in advance Link to comment Share on other sites More sharing options...
frank1331 Posted September 15, 2006 Share Posted September 15, 2006 I can only help with the first question. You can type gc() and it will clean things up. You wont be able to see what it is cleaning like autocad, just have to trust it. Link to comment Share on other sites More sharing options...
jtiscareno Posted September 15, 2006 Author Share Posted September 15, 2006 Type g and then c and it brings up the camera box??? Link to comment Share on other sites More sharing options...
BrianKitts Posted September 15, 2006 Share Posted September 15, 2006 no down in the bottom corner type "gc()" then ENTER (see attached) i think gc stands for garbage collector Link to comment Share on other sites More sharing options...
Msamir Posted September 15, 2006 Share Posted September 15, 2006 I remember that this doesnt work except for earlier versions than 8. Link to comment Share on other sites More sharing options...
jtiscareno Posted September 15, 2006 Author Share Posted September 15, 2006 Thanks brian for the clear up, typed gc() in the corner but didn't seem to do much... Any ideas or suggestions for the other two questions: slice modifier and rpc script? thanks Link to comment Share on other sites More sharing options...
jtiscareno Posted September 17, 2006 Author Share Posted September 17, 2006 Hey guys any tips on the slice modifier animation???? Thanks Link to comment Share on other sites More sharing options...
only3d Posted September 20, 2006 Share Posted September 20, 2006 dont know about the RPC but for the slice animation u have to activate the 'key filters' to the right of the 'set key' button, so either u activate the appropriate one or just activate all of'em. thats the difference between 'set' and 'auto' which decides on its own good luck Link to comment Share on other sites More sharing options...
Matt Clementson Posted September 20, 2006 Share Posted September 20, 2006 akzit said: 1. Is there a way to "purge" a max file like in autocad? The two are not analogous. Max doesn't keep definitions of layers/linestyles/blocks like AutoCAD does. Objects that are delete are deleted and are not kept in the file. The given gc() will clear anything temporary in memory but all temporary objects are not saved to the file. So you don't need to 'purge' a MAX file like you do an AutoCAD one. Link to comment Share on other sites More sharing options...
jtiscareno Posted September 25, 2006 Author Share Posted September 25, 2006 only many many thanks, I knew I had a setting off but could not figure which one, thanks!!! Matt thanks for the info on the purge. So 2 down, anybody have the same issues with max8 and the sil script??? Link to comment Share on other sites More sharing options...
