Noise Posted September 19, 2006 Share Posted September 19, 2006 Hi I have a drawing in from a client and it looks fine in plan view but, when it is viewed in axo or elevation - the lines are all over the place in the Z coordinate. Is there a way to bring them all back to 0 in one go ? I have tried a lisp routine that is meant to do this but it won't work. thanks N Link to comment Share on other sites More sharing options...
slinley Posted September 19, 2006 Share Posted September 19, 2006 If you assign the Text in the attached file to a custom button and then run it that should bring all your points back down to 0. Stu Link to comment Share on other sites More sharing options...
bdonay Posted September 19, 2006 Share Posted September 19, 2006 Try the flatten command. Link to comment Share on other sites More sharing options...
Noise Posted September 19, 2006 Author Share Posted September 19, 2006 Thanks I don't want to sound crap but, how do I create a new button ? Its been a while since using acad regularly. thanks n Link to comment Share on other sites More sharing options...
Noise Posted September 19, 2006 Author Share Posted September 19, 2006 When I type flatten into the command panel, it doesn't recognise it. Link to comment Share on other sites More sharing options...
Thiago de Andrade Posted September 19, 2006 Share Posted September 19, 2006 In older Acad versions "flatten" is a express tools feature, so you'll have to install it. But, does flatten work for lines with differente Z coordinates? I only acomplished to use it to lower coplanar lines, all of them with the same z coordinate. Link to comment Share on other sites More sharing options...
jackb602 Posted September 19, 2006 Share Posted September 19, 2006 I don't know if this works in Autocad, but in FormZ I select all the lines and scale them 1,1,.00000001 so they are effectively flattened along the Z-axis. Link to comment Share on other sites More sharing options...
slinley Posted September 20, 2006 Share Posted September 20, 2006 Creating a button depends on what version of Autocad you are using as Post 2005 its a very different setup to previous versions. If you are using 06/07 then type in CUI, then on the bottom left section of the interface it says Command List. Click on the flyout and select custom commands and then new. You can rename your button, paste the text into the Macro slot and Apply. You can then drag this from your list on on the bottom left into one of your toolbars at the top left. Hope thats not too complicated and i'm afraid i can't quite remember how to do it in 2005 or before. Link to comment Share on other sites More sharing options...
Noise Posted September 20, 2006 Author Share Posted September 20, 2006 I am running acad 2002 ! Insane, we need to upgrade but I am sure it should be possible to sort this problem with this version. thanks n Link to comment Share on other sites More sharing options...
slinley Posted September 20, 2006 Share Posted September 20, 2006 Okay, think this should do it. Go to Tools > Customize > Toolbars > Commands > user defined(Bottom left) Select a new button in the right hand area(should only be a few) and drag it onto your screen. If you then click on it you should get the preoperties of it and then just rename and paste in the macro. Ok that and then you should be able to use it. Hope it does it this time. Link to comment Share on other sites More sharing options...
Noise Posted September 21, 2006 Author Share Posted September 21, 2006 Slinley you are a genius - thanks for that ! n Link to comment Share on other sites More sharing options...
