3d people collection URGENT!
wturner_99
the proviz ones are animated poorly and they don't look that good. they don't need character studio, but they do look unnatural. i couldn't find 3d models on the archivision site.
i really like the look of the aXYZ products. you can get still packages or animatable ones that use motion capture data that looks correct in an animation...
http://www.axyz-design.com/
Hi Chuck
Thanks for your info. I mistyped the link, it was supposed to be: http://www.archvision.com. They have some 3D collection there although the cost is substantially higher than http://www.proviz3d.com
The axyz collection is very good although the price of is higher than proviz3d. Any other alternative beside axyz with the same price range as proviz3d?
regards
WT
RPC is a substancial resolution that you can get away with them at a decent size. If you are going really high res with them up close, they have a high resolution library if I remember correctly.
But you also have to be aware that they can do funny things sometimes, specially when rendering with GI. Sometimes you have to be a little selective to what RPC's you use so that they fit the scene, alot of them look over-bright or the lighting just doesnt match, no matter how much you tweak their settings. They also can get funky with their reflections sometimes, the reflection on a floor might start a few inches from their feet as opposed to right at the feet as they should. And they don't do well for aerials, once you get above a certain angle they look odd.
I'm not a huge fan of them, but maxer is right..... they work well, but don't go in to your purchase thinking they're perfect. So it's a trade off. RPC's are more realistic, but sometimes they kill the realism of the scene buy not matching the lighting and the stick out like sore thumbs. Some of the other libraries you mentioned of modeled low-polygon people will fit with the lighting but don't look as realistic from a close view. So it basically depends on how you plan on using them.
Sounds like its too late, but for what it's worth I agree with Maxer the low poly 3D people do look like monsters and in our light setup they sure didn't render well.
The RPC stuff is easy and fast. They may not look fantastic but neither do the low poly people. If "it looks ok" is the best I can do I'll take the "ok" that has fewer polygons and that's RPC.
