High building animation
sedus69
More Images to see at http://avulhnaut.free.fr/boiss/
A few more try
I am working on a big project (it is big for me), because i usually do only Still image. the client wants an animation (3 min lenght) whit tree, shrubs, plam tree... Moving people, moving Cars...
A little ADD before the big JUMP into the rendering
----> http://avulhnaut.free.fr/boiss/Terr_test.mov
You will find there my last test before launching every frame.
And I need some help to improuve the quality, I still got some Flickering for tree shadows despite using High Quality mode:
Image sampler> AdaptSubs 0,2 Area 1.25 (RAndom OFF)
Indirect GI Primary 1,0 Irrandiance , Secondary 1,0 Quasi MC
Preset High Hsp 35 Inter 25
Multiframe every 25 Frame
Quasi Montecarlo subs 8 Secondray 4
Rqmc Samples 10
Rendering time is quite good 2 min -> 6 min / frame on Opteron 165 (6 Min where there is a lot of little flowers... red ones at the end)
But If you have any tips to improve rendering time and Quality TELL Me !
So I try to do my best, Proxy and instance Tree (Onyx) add some Axyz model inside, But Rendering is about 6-10 Min on a Opteron 165 (got 4 of them) without any animated characters.
So the question is, how to add Anamated Cars ans characters, i did a test with Full Gi on every frame, the only way to add animation, it takes ages to render only 1 frame (35-50min).
Tree and flowers Onyx + Vray Map, Bionatics + Vray Map
I tried the "VLADO" ways of easy compositng for Vray and animated character... http://www.spot3d.com/vray/help/150R1/tutorials_anim.htmVery painfull to do, and SO time consuming to render 4 Passes. And i Lost the capacity to add Motion blur under Combustion (RPF velocity).
As i Got Combustion, is there any way to Render the full animation (Fly thought) and then just add those animated cars and people.
I really don't have much experience with Vray and animations, so this might sound ghetto (think elvis). Any way, how about using vray's light cache? You can calculate the GI every 10th frame or so as a walk through. Vray lets you exclude cars/people from the GI calc right? This might work, and it might look odd. I guess it depends on how close you will be getting To the animated content.
Are you using IR map now? What are your settings?
Nice site BTW...very interesting.
Chuck
I already use Irrmap + Lc, works great for Walkthrouht, and yes i exclude every animated object. Great render and Fast, execpt First Frame.
Irrmap settings are basic, but only High animation , hsp 20 but global multiplier 2 (it adds some details).
But don't have a clue to add animated cars with shadows...
Yes, Irradiance Map and Light Cache is definitely the best solution for static geometry animation...no reason why you cant be getting render times of around 60 seconds if you are careful with your settings
Only problem is once you introduce moving elements the light cache and irradiance map require updating each frame....think the best solution is to wow your client with such a nice animation, and he wont notice the static cars ;)
We noticed on our vray animations that we could get away with rendering all animated people/cars with scanline renders and composite them on top later. Much quicker in the long run. Just throw a map shadow on everything on your scene and go!
Hope this helps.
yes....good idea....this has worked for me in the past aswell
One thing I just did in an animation was just to have the moving cars and people not part of the irradiance map and light cache calculations. Once those were done, turn the cars and people back on, and I was good to go. Worked way better than comping them in. Especially because I haven't had much luck in comping.
I've just tried what you suggest. Works quite Fast but objets Not in GI looks flat, but I can live with that, maybe I will BAKE some Gi ont those Objects just to add some nice shadow.
I still Wonder How people like Icube.ru do to have such nice car and animation. maybe talent, but it is only 2% of work, 98 % is Good modeling, good techniques.
And maybe their 40 Pc render Farm helps a Lot.
  • 3 weeks later...
the animation looks pretty good...
two things jump out at me though:
- your camera path is a little akward. sometimes it just moves in an odd way, but it's also hard to understand what you're trying to show the viewer. seems random in the middle when it's right over that roof.
-the second thing is the pool water. that should get better as you get closer to the final, but right now it's off. it just doesn't look like water to me. what are your plans for the sky in the final?
the lighting looks good, there's just a little funk here and there around the tree's shadows. nothing to be worried about though.
entourage looks good, are those trees and bushes evermotion? i'd really like to see the final when it's done, it should look really good.
chuck
Great stuff, can I ask where the vegetation is from? I think the small pines, and the tall grasses in the corner are some of the best 3D vegetation I have seen.
Only issue I see is the fast camera move. Slow it down and you have a great looking piece.
Good luck.
Okay I will slow down a bit the camera, and focus ave some interresting Point.
Has I have to produce a 3 Min animation lenght, I ll try a 40 sec Animation about this ROOF garden/swimming pool.
About vegetation Mix between Evermotion Volume 31 (But remove all Glossiness VERY CPU consuming) Onyx for Palm and Bionatics Nat Fx (not so good, but we but It !)
just put some basic texture, mapping of flower, Grass... anything related to vegatation in fact, it helps to remove uniformness (if the word exists)
Hope it helps.
Jard_0050.jpg.
I need help with Grass.. it looks terrible, I use a Jpg (3500*2500 px) mapping for the entire Garden (not so big 50 m * 25m)
And the grass Look a lot better in photoshop, and with Standard Max Scanline render. Need help, I can't use Displacement cause it is an animation,
I will try tu put more Schrubsn and things to "cover" this mapping.
More Images at http://avulhnaut.free.fr/boiss/
Need help !!! Render is... REALLY near now.
  • 2 years later...
