GD77 Posted September 21, 2006 Share Posted September 21, 2006 hello: am using backbuner 3dsmax on net rendering for 8 pcs and found that all the jobs assigned to the rendering que halt every certain time, then recontinue by starting from where they 've stoped, duno the reason, does not seems to be a net problem or anything so far, thanks in advanced. just downloaded backburner 3.02 removed the old one on some pcs and reinstalled it form 5 pcs 2 of them i get this eror message after receiving job from the main manager and launching 3dsmax: "general exception handled tcp thread. connection terminated." so far even can t find solutions nor on autodesk web or google. if someone knows a solution for this i ll be thankfull Link to comment Share on other sites More sharing options...
IceAged Posted September 21, 2006 Share Posted September 21, 2006 Are all your pc's running XP? A good start would be to make sure each pc is set up in the same way as the others, (same opperating systems where possible, latest service packs, identical network settings, etc). Also make sure that Max is updated with SP3 on each pc, and that you are running the latest version of backburner on all of them. Another thing worth checking is firewall settings - make sure your firewalls are set to allow communication between the backburner server and manager. Alternatively you can just disable them if this is feasable. I can't give you a specific answer to your problem, but i run a render network with about 20 pc's, and most of the problems that come up are caused by unusual settings on individual pc's. Try narrowing down the problem by rendering with just one other pc, and slowly add the others until you identify the problem computers. Link to comment Share on other sites More sharing options...
GD77 Posted September 23, 2006 Author Share Posted September 23, 2006 Hello: Thanks For The Reply and yes all my 8 pcs run Xp pro same installation cd same 3ds max 8 sp3 using switch hub stdLab 16 ports, no internet on any pc but i ve noticed 2 things a user in the office installed max 7.5 when i ve removed it i had to reinstall max 8 and backburner 3.02 and the main that I ve noticed the big diffrence with is the time, yes each time pc had to be synchronised to the minute noticed it when i was rendering a scene using rpc on the net and i was installing rpc installed on another pc same time IT poped up a message saying that ''time is not synchronised'' on the installed machine with where the rcps where installed on the net, anyway today i ve rendered on the 8pcs so far the problem had disappeared hope it will never show up thanks again for the help. Link to comment Share on other sites More sharing options...
