Andrew Roane Posted September 22, 2006 Share Posted September 22, 2006 Hey, I am building this model of a house just for practice, and I have these dark black areas that I don't know how to get rid of. I tried applying a brick texture, but the black shows up in the rendered image as well. How can I fix this?...or, how can I prevent it from showing up in my models to begin with? Thanks. Link to comment Share on other sites More sharing options...
Sketchrender Posted September 22, 2006 Share Posted September 22, 2006 Re build the block that is black trust me it is a point that is off. Link to comment Share on other sites More sharing options...
mooney102 Posted September 22, 2006 Share Posted September 22, 2006 What are you rendering with? I have been having the same problem, I think that whenever there is doubled up objects, Vray 1.5 will render them out black. Any feedback would help on this issue. Link to comment Share on other sites More sharing options...
richmondlu Posted September 22, 2006 Share Posted September 22, 2006 Check your normals..If they have that in max? If you do your going to want to harden your normals. Link to comment Share on other sites More sharing options...
Andrew Roane Posted September 22, 2006 Author Share Posted September 22, 2006 I am rendering with the standard scanline renderer. I don't think that the render engine is the problem though, because it was showing up before I ever rendered the image. I'm going to try and find a way to harden the normals, and I'll see if that works. Thanks. Link to comment Share on other sites More sharing options...
jsf Posted September 23, 2006 Share Posted September 23, 2006 3ds max does wierd stuff like this with lofts and sweeps when they turn corners. To solve it, try creating a new loft or sweep with a straight line segement and then miter the corner manually. Use boolean subtract or a method of your own choosing. UVW mapping will be easier with these new individual profile segments. Link to comment Share on other sites More sharing options...
Matt Clementson Posted September 26, 2006 Share Posted September 26, 2006 That just looks like a smoothing group error to me. Apply an Edit Mesh modifier (if it not an editable mesh already), select all the polys and apply an auto-smooth - should sort it out. Link to comment Share on other sites More sharing options...
anvaraziz Posted September 26, 2006 Share Posted September 26, 2006 its a smoothing group prob... u can remove or edit the existing smooth value to fix it.. Link to comment Share on other sites More sharing options...
LukeC Posted September 27, 2006 Share Posted September 27, 2006 it looks like you might need to weld some points that might be duplicated in that area Link to comment Share on other sites More sharing options...
Andrew Roane Posted October 3, 2006 Author Share Posted October 3, 2006 It turns out that the problem arises sometimes when the 'smooth length' and 'smooth width' boxes are checked for a loft which has angular corners. The same applies to the sweep modifier when smooth section and smooth path are checked. Unchecking those boxes has resolved the issues so far. This obviously should not be checked if you need to have a smoothed final object. Thanks Everyone. Link to comment Share on other sites More sharing options...
hooman_71 Posted October 4, 2006 Share Posted October 4, 2006 hi I'm in agree with philip , sometimes rebuild the mesh is the best & fastest way to get rid of such things in 3dsmax. Link to comment Share on other sites More sharing options...
