1eo Posted September 22, 2006 Share Posted September 22, 2006 I'm using AutoCAD 2006. Let say I have this situation: is there a way to force the 4'-2" dimension so it would not cross the dimension underneath. In other words, there would be a "break" on the 4'-2" line so it's less confusing.... I could stop the dimension and simply add an extra line... but I'm afraid if the window changes position I could end up with the wrond dimension. Hopefully the question is clear , I had a hard time wording it Thanks! Link to comment Share on other sites More sharing options...
vizwhiz Posted September 22, 2006 Share Posted September 22, 2006 hi There Leo it is best To leave The dimensions intact, especially since They should be associative and update when necessary Try adding a 'wipeout' mask where you want The crossing dimension To be 'suppressed' well, This aint The best idea either, it may not work you would almost have To have 2 separate layers with one Layer of dimensions in 'front' and with another layer 'behind' for the 'wipeout' To work ** as you said if you 'break' The dimension Then it wont be associative you should put This idea of yours on The AUGI wishlist, There is a link somewhere at The AUGI website for Autocad wishlist ideas ** ok, This isnt very helpful but you bring up a d@mn good point randy Link to comment Share on other sites More sharing options...
1eo Posted September 22, 2006 Author Share Posted September 22, 2006 I was not aware there was a comand called wipeout.... real nice find!! leo Link to comment Share on other sites More sharing options...
bigroo Posted September 22, 2006 Share Posted September 22, 2006 You could always hide the extension lines in the item properties and still keep the association. Link to comment Share on other sites More sharing options...
1eo Posted September 22, 2006 Author Share Posted September 22, 2006 You could always hide the extension lines in the item properties and still keep the association. could you elaborate? I'm not sure what you mean... Link to comment Share on other sites More sharing options...
BobM Posted September 22, 2006 Share Posted September 22, 2006 In that situation I would put a temp construction line from the item to the first dimension line and then dimension from that then erase the line. Then you would have a short dimenson line above Link to comment Share on other sites More sharing options...
bigroo Posted September 24, 2006 Share Posted September 24, 2006 could you elaborate? I'm not sure what you mean... By selecting the dim line extension 1 (or 2) 'off' you hide it and avoid the crossing effect that you have. Link to comment Share on other sites More sharing options...
Brian Smith Posted September 24, 2006 Share Posted September 24, 2006 Leo, I'm pretty sure i understand what you're asking...and if so there's no way to do what you're asking...at least not automatically. I'm wondering, however, why your smaller dimensions would be above (on the outside) of larger dimensions. That's not good drawings practice and would confuse and lead to a number of problems. If you're dimensioning a window and the wall that the window lies, you would place the smaller window dimension close to the wall and the larger wall dimension away from the wall. Sorry if I'm stating the obvious but I just can't understand why you would want to do what you're trying to do. Link to comment Share on other sites More sharing options...
1eo Posted September 25, 2006 Author Share Posted September 25, 2006 Leo, I'm pretty sure i understand what you're asking...and if so there's no way to do what you're asking...at least not automatically. I'm wondering, however, why your smaller dimensions would be above (on the outside) of larger dimensions. That's not good drawings practice and would confuse and lead to a number of problems. If you're dimensioning a window and the wall that the window lies, you would place the smaller window dimension close to the wall and the larger wall dimension away from the wall. Sorry if I'm stating the obvious but I just can't understand why you would want to do what you're trying to do. thanks Brian, I was asked to do it in that way, because the windows are more important than the a/c metal pad (overhang). Link to comment Share on other sites More sharing options...
Brian Smith Posted September 25, 2006 Share Posted September 25, 2006 I understand...if you're told to do it that way then I guess you gotta do it that way...but it's still bad practice. One of the big problems that this can create, besides creating expensive confusion during the building process and the lack of respect the contractor will have for whoever but the drawings together, contractors will often see this as a sign that they need to bid high on a project...because if this is example of how drawings are put together, then what else is wrong with the drawings. I've dealt with numerous contractors that have this kind of mentality. Link to comment Share on other sites More sharing options...
Guest IG Oliver Posted September 26, 2006 Share Posted September 26, 2006 I totally agree with you brian. I work for a japanese firm and they are totally strict in their drawings. Dimensions are most important during the actual construction and that's the reason why they implement a standard even in dimensioning drawings. Link to comment Share on other sites More sharing options...
neko Posted September 28, 2006 Share Posted September 28, 2006 yup - brian is absolutely correct. dimensioning standards are very important for clarity, and if they are not practiced it leads to the impression that other aspects of the drawings might be wrong as well. Link to comment Share on other sites More sharing options...
1eo Posted September 28, 2006 Author Share Posted September 28, 2006 I understand...if you're told to do it that way then I guess you gotta do it that way...but it's still bad practice. One of the big problems that this can create, besides creating expensive confusion during the building process and the lack of respect the contractor will have for whoever but the drawings together, contractors will often see this as a sign that they need to bid high on a project...because if this is example of how drawings are put together, then what else is wrong with the drawings. I've dealt with numerous contractors that have this kind of mentality. I was told the opposite... contracts bid lower and later made their money on change order due to bad drawings. In this particular case... we are also the contractor so no problem there. We have never had any big issue with any contractor.... ( yet, this is the first time where the dim got me confused as I would have done it differently too. ) Link to comment Share on other sites More sharing options...
