Bedroom
muzzy
if u really want a critic i could say reflections in the water don't seem really natural
too sharp and saturated i guess .... or maybe so water seems a little flat like a pool.... isn't it supposed to be a river?
veery nice work anyway!
I think it is very nice :) the only thing is that the plant outside in the balcony. it should cast shadow and I dont know which renderer you are using but if you turn off image sampling off and take a render of this plant and then insert it into your render, I think it would look better.
I will fix the shadow problem of the plant.
Kingeldar.. Water & trees comes from env. map. Not included in render.
I will try your suggestion giraffe. BTW it is vray + max
Thank you for your commnets.
besides the plant on tehbalcony, i see 2 weird things:
There are 2 lines on the wall that looks like a "crack", 1 is between the painting and the little table and the other one is above the painting, where the wall meets the ceiling.
I think it is Fantastic
I'm new at this & need help.
Can you tell me how you did the lighting & where did you get the artwork for the wall
thank you for your nice comments..
I found the image searching google images "dali"
For lighting there is one direct light for sun, one vray light in front of the window to bring more light.
