maseo Posted September 26, 2006 Share Posted September 26, 2006 Hi all! I've got this seriously anoying thing going on with my Vray and HDRI settings. I've set up DR to work properly, but when it comes to HDRI the 2nd node won't render it. I've checked the acces to the file and its USC (\\computername\location, instead of X:\location), but still the second pc won't render the HDRI file. What's the deal ? Link to comment Share on other sites More sharing options...
lambros Posted September 26, 2006 Share Posted September 26, 2006 I tend to copy all map files locally to avoid this situation. Doesn't always happen, but when it does it is annoying. Link to comment Share on other sites More sharing options...
Thablanch Posted September 26, 2006 Share Posted September 26, 2006 Usually \\path are solving the problem... Are you running it on Viz or Max, cause Viz does have some issue with maps, that are apparently solved in 1.5 Link to comment Share on other sites More sharing options...
