TRUSTYGUY Posted September 26, 2006 Share Posted September 26, 2006 Hi guys....I've been wondering is there any way to transfer ADT objects such as the walls or windows or doors..etc. to 3DMAX...I know that it can be directly linked using 3DVIZ, but I am actually using Vray which I have installed into MAX while VIZ has its own setup specialy the one which comes with the ADT....any ideas/solutions ? Thanks. Link to comment Share on other sites More sharing options...
Justin Hunt Posted September 26, 2006 Share Posted September 26, 2006 the linking is the same as Viz although you may have to install the relevant object enablers from the autodesk support website If you are using Max8 the install SP2 or 3 as the File Link Manager is broken with out it JHV Link to comment Share on other sites More sharing options...
vTay Posted September 26, 2006 Share Posted September 26, 2006 ok friend you can go to www.autodesk.com and then go to architectural desktop and select updates and service packs download ADT object enabler for ADT2006 and if you have MAX8 just download 3dsmax8 service pack3 and download the REALDWG update and then enjoy Link to comment Share on other sites More sharing options...
