Revit 8 Trial - no libraries
P.R.S. Sivakumar .
Hello everybody
I have just installed Revit 8 trial version (which is a fully working version but will not save file or print a file). I found that there are no Imperial Templates nor any door/window libraries etc. I chose "Full Install". I even reinstalled the entire software. But still these were missing. I searched the installation CD and even there I did not find them. Are these deliberately not covered in trial versions?
Thanking you in advance
PRSS
Hello everybody
PRSS
hi :) http/revit.autodesk.com/download.asp;)
Hello everybody
PRSS
Hi Sivakumar, during installation of revit it will ask you whether you will be installing it with metric or imperial units. If you select metric by default the metric contents (library) and templates are checked in the dialog box and it will be installed but you also have an option to include imperial content and template by simply checking the box provided for this options.
As for exploring the cd you can't find the content and template in there as they are compressed in .cab file.
Hope this helps.
